Settings and other general questions
Posted: Sat Feb 07, 2015 2:01 pm
My TIG welding can be summed up as many years off and on with various machines and hi-frequency attachments. Five years ago I bought a new Miller Syncrowave 200 transformer machine. At the time I wanted an "stick" machine that could also do TIG. Now after doing more research I might have been better off just adding an inverter TIG to my shop, but this is what I have so I hope to learn how to use it proficiently.
The following practice piece is some .125 5053 aluminum that I'm just running beads. I was trying to experiment with different size tungsten and type. Right now I've settled on pure tungsten that seems to be more stable than others I have in the drawer. It balls up and seems to create a nice concentrated arc and puddle. I was trying to help myself with filler rod timing using the pulse setting at 1 second but I must be doing something wrong since it was cooling the puddle too much and I was increasing the amperage a lot higher than without the pulse. The manual with this machine is not very descriptive and I'm sure there is a setting I'm not using that would let me keep a more even setting between high and low pulses. So far I'm giving up on that idea and just using the peddle for amperage control.
I'm using a water cooled torch and a 3/32 tungsten. I have a #7 cup on a gas lens setup. The last pass was at about 85 amps. Any tips are helpful. Thanks in advance.
