Rajasekar
    Sat Mar 14, 2015 10:43 am
Friends
Am trying to get certify for bearing welding but specification cracks comming.Am new for this welding....
parameters using
Miller syncrowave
Amps 230 to 250amps
Post flow time 9 sec
Plate is low carbon for testing 10mm thick
It is not straight LINE welding.that plate has 3 holes 0.22 inches.in that holes 0.22 inch pin has to place and weld for certification.welding around 6 seconds
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
Welcome to the forum.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
Rajasekar
Hi thank you.
    Wed Aug 06, 2014 12:48 am
    Melbourne, Australia
Rajasekar wrote:Friends
parameters using
Miller syncrowave
Amps 230 to 250amps
Hi
Thanks for the request and the detail you already sent
Any chance you can send a photo of the item being welded?
(PS: Welcome also to the Forum)
Trevor
