The school has a Lincoln Electric Invertec V205-T Welder, and I have it set up on AC, with about 15 cfh of argon, 100 on the Frequency, and the Balance at 85. I am welding 1/8" coupons, with a 3/32 tungsten, and trying to use a filler rod close to the size of the tungsten. As per your videos, I keep the stick out within the diameter of the cup, and a tungsten diameter away from the metal. I also use a stainless brush on the metal before welding, and have the tungsten grinded to a point.
The problem is that my welds are very flat, usually leaving over an 1/8" depression into the metal, with a large bubble on the back. My hand speed is pretty fast (1" every 5 sec), and I keep the puddle the same size. I have the machine only set up at around 70 amps, even tho Miller recommends 125 for 1/8" Aluminum. If I set it any lower, I have problems starting a Puddle, and any higher and the Melting gets alot worse. Adding Filler Rod doesn't seem to change the height of the weld too much either.
I watch your videos on Tig Welding Aluminum and you make it look pretty effortless, even thought I know how hard it is now >.< ...In your videos you are able to stack a bead right on top of the Aluminum without any type of distortion or sinking of the metal around the weld, and you are able to continue to weld beads right next to each other, without too much time to let the metal cool.. Do you have any advice you could give me on this problem? Thanks in advance to any help you can give me, and also thanks for amazing website.
