Who runs a filter on there watercooler?
Posted: Thu Feb 18, 2016 12:32 am
by melsdad
Was thinking of adding one to my system. A quick search brought me to this type.
http://www.brwtechnologies.com/Torchsav ... %20510.htm
If you do use a filter. What make and model is it?
Re: Who runs a filter on there watercooler?
Posted: Thu Feb 18, 2016 11:57 am
by Artie F. Emm
I've been meaning to piece together a water cooler, and was going to put a fuel filter inline.
Posted: Thu Feb 18, 2016 3:10 pm
by rick9345
water will plug/restrict a fuel filter
need filter designed for water.
Posted: Thu Feb 18, 2016 4:42 pm
by Louie1961
don't run one. I have distilled water in mine and it is not in the sunshine. Never thought there was a need for one.
Posted: Thu Feb 18, 2016 5:56 pm
by dynasty200sd
If you are running a Procon Series 1 Pump with an integral strainer, the strainer's job is to keep particles big enough to damage the pump out of it. If the pump used doesn't have a strainer, then all you'd need to do is install a t-strainer which is what a lot of the water coolers use.
As for the Procon Series 1 Pump, it uses a 100 mesh wire screen inside the strainer.
Posted: Thu Feb 18, 2016 7:04 pm
by melsdad
dynasty200sd wrote:If you are running a Procon Series 1 Pump with an integral strainer, the strainer's job is to keep particles big enough to damage the pump out of it. If the pump used doesn't have a strainer, then all you'd need to do is install a t-strainer which is what a lot of the water coolers use.
I don't believe the Everlast coolers use a procon pump. IIRC It is a pump made in Italy so I'm not sure if there is filtration built into it or not.
I guess I will just go ahead and add a filter. It sure can't do any harm as long as the correct filter is used.
Posted: Thu Feb 18, 2016 9:49 pm
Why a filter, it's a closed system?
Posted: Thu Feb 18, 2016 10:17 pm
LtBadd wrote:Why a filter, it's a closed system?
You'll be stunned by what gathers and moves in a closed system. Even in a 100% distilled water system, the water becomes an aggressive solvent attacking anything not 100% inert. The vinyl or other plastic tubing will sluff off material over time. Heat will accelerate this in the return line.
A 100-mesh screen is good insurance.
Posted: Thu Feb 18, 2016 10:44 pm
Think if I were to put an extra filter on a cooler besides the strainer screen I would put it after the torch but before my resavore. So as to not cavitate the pump if the filter got plugged.
Posted: Fri Feb 19, 2016 8:26 am
by Artie F. Emm
rick9345 wrote:water will plug/restrict a fuel filter
Thanks, i'll tethink this.
Posted: Fri Feb 19, 2016 12:20 pm
by Skylineauto
I know the fill cap on my Miller is vented. When the coolant expands and contracts with heating and cooling it will suck in dust.
Posted: Mon Feb 22, 2016 1:14 pm
by hey_allen
I bought a filter that looks identical to the one pictured above from McMaster for under $10.
My thinking is that it's cheap insurance against damaging the $200+ torch.
Posted: Mon Feb 22, 2016 1:19 pm
by melsdad
hey_allen wrote:I bought a filter that looks identical to the one pictured above from McMaster for under $10.
Would you buy chance have the part number for the filter you bought?
Posted: Mon Feb 22, 2016 2:05 pm
by griff
I wish I had on my old Dialarc250. I had it eat two torches and the coil got clogged up. Apparently my pump is plenty healthy as it popped the coil on the cooler when it clogged. Coolant had been changed several times in the machine that I know of.
Posted: Mon Feb 22, 2016 4:01 pm
by dave powelson
- 44305k25p1l.png (7.32 KiB) Viewed 1838 times
In stock
$12.62 Each
44305K27
This version with hose barbs added, goes in line in coolant hose.
In use for 18 years. Replaced cap o-ring once.
Posted: Mon Feb 22, 2016 6:21 pm
by hey_allen
melsdad wrote:hey_allen wrote:I bought a filter that looks identical to the one pictured above from McMaster for under $10.
I bought part number 98775K414 for $8.33.
Posted: Mon Feb 22, 2016 7:38 pm
Thanks for the number, defiantly a "best buy"
Clean out your strainer less often—a T-shape body provides greater dirt-holding capacity than Y-strainers. Strainers have a black glass-filled polypropylene head. Screen is Type 304 stainless steel and seal is EPDM. Connections are NPT female.
Strainers with clear bowl allow you to monitor debris without disconnecting your pipeline. Bowl is nylon.
Posted: Mon Feb 22, 2016 8:36 pm
by melsdad
hey_allen wrote:melsdad wrote:hey_allen wrote:I bought a filter that looks identical to the one pictured above from McMaster for under $10.
Thanks! I will be ordering one.
Brian
