Which joint would be stronger?
Posted: Tue May 10, 2016 1:50 pm
by Kriky
Which joint would be stronger? I know which would look nicer but is there a difference in the strength? I'm building a cart that will be 2'D X 4'W X 3.5'H. Bottom frame will be 1"x2" aluminum 6061 T6.
Re: Which joint would be stronger?
Posted: Tue May 10, 2016 2:03 pm
by DLewis0289
If that is angle you are showing, coped or 45'd would be fine.......
Posted: Tue May 10, 2016 2:08 pm
by Kriky
Yes, sorry I meant the angle. Thanks for picking up on that and thanks for the info.
Posted: Tue May 10, 2016 2:17 pm
by exnailpounder
What is the cart for and how strong does it need to be? If it doesn't need to critically strong then I would go for pretty.
Posted: Tue May 10, 2016 2:41 pm
by Sandow
Which is stronger? Well, kinda neither. You are better off doing a fully open corner joint. Pretty easy joint to weld nicely too.
-Sandow
Posted: Tue May 10, 2016 2:51 pm
by Kriky
I'm not sure what you mean by a fully open corner joint. Btw it is a 1/8" thick 1"x2" aluminum tubing.
Something like this?
Posted: Tue May 10, 2016 3:07 pm
by Sandow
Oh, I missed that those drawings were square tubing. The copped joint is stronger.
-Sandow
Posted: Tue May 10, 2016 3:54 pm
by big gear head
The top joint with 45 degree angles is definitely stronger.
