Dennis Hrvatin
- Dennis Hrvatin
Can pure argon be used with mig welding without causing problems? I have tried it, seems to work, weld seems a little dirtier and no crackle sound and very few sparks while welding. Cheers
Yeah, aluminum needs straight Argon. Steel needs 75/25, etc, for best quality. You get a taller bead, less penetration, more undercut with Argon.Don't know about S/S.
Lincoln Weld-Pak 180
Lincoln spool gun
Everlast PowerUltra 205p
AHP AlphaTig 200X
Assorted stuff
Lincoln spool gun
AHP AlphaTig 200X
Assorted stuff
The issue is that you don't have the active part of gas (carbon dioxide, oxygen or both) to create arc force
That's why you don't get the same characteristics of a mig weld, but still get the inert shielding (no porosity)
