BigMclargeHUGE
    Sat Mar 19, 2016 4:11 am
When you're welding fillet welds on a 90 degree T-bar what are the proper work angles for the 6 beads to be stacked? Like.... 1 2 3 4 5 6?
Revocide
    Mon Nov 02, 2015 9:05 am
Hi BigMc
I'm no master fabricator, more enthusiast than professional. My 2 cents.
If you are doing horizontal runs on a 90 degree joint then I would think that the multipass runs would go something like.
1 - 45 degrees
2 - at the bottom edge of first pass at about 60 degrees
3 - on the top edge of second pass, say 30 degrees
4, 5 and 6 in the same order as 2 and 3 but at 45 degrees.
Any further runs would be stacked on from bottom to top. As for your tie ins and so on, this is beyond my level of advice.
Revo
