FarmBoyCustoms
- FarmBoyCustoms
This is my first big weld job. Learned a lot, but at least the welds are strong and not bad looking. Will make sure to clean everything thoroughly, remove splatter and invest in some wire brush attachments for a drill.
- wl-j.JPG (81.68 KiB) Viewed 1648 times
Good stuff. Also, take that magnet off after taking, before welding. It'll ruin the magnet and could play hurry curry with you weld.
FarmBoyCustoms
- FarmBoyCustoms
Ok so use the magnets, clamps check for square. Tac in the pieces, let them cool, take the magnets off and then weld. Gotcha! Thanks for the tip
- timothymass
here is some stainless 304 and a solvent tank I welded up for my garage
- 20150418_010728.jpg (21.31 KiB) Viewed 1582 times
- 20141202_180203.jpg (27.81 KiB) Viewed 1582 times
- TRACKRANGER
Nice JDIGGS82
It would be really great if you could advise your settings, amps, machine, wire feed speed, wire diameter, materials thickness, gas flow rate, technique etc. This would really assist others.
Nice job
Trev
Nice job
Trev
Torched off some rusted out metal (step area) from my demolition trailer, put some less rusty metal in its place.
.045" hard wire, 100% CO2
- Metal
- image.jpg (60.75 KiB) Viewed 1580 times
- Machine
- image.jpg (73.76 KiB) Viewed 1580 times
rahtreelimbs
- rahtreelimbs
309 flux core on one side, s6 on the other. The s6 didn't etch well.
