Hey all,
Had a conversation with a shop manager the other day where he said that too many of the guys are pulling as they make their welds and consequently are causing micro arcs down inside gun damaging the area around where the gas fitting sits in the cup.
This is something I had never heard of and can't seem to locate any real info or articles on. I've heard the usual differences between pulling/pushing, ie. penetration/visibility etc. but never anything about damage to the equipment. Any truth to this?
It's a miller deltaweld style machine, used mostly for heavy equipment crack repair and light fabrication, medium duty for its capabilities.
Irrespective of the normal argument between pushing and pulling, I never heard anything about it damaging the equipment. And just about every flux core weld I've ever seen was dragged. More likely using the torch as a chipping hammer that does it. If you are not on flux cor, roughly treated equipment is still the most likely cause. We've had an issue where the torches caused issues with the machine but that was a defective design of torch. Once we swapped brands of torch, the issue went away and has never returned.
Shop manager is talking out of his "other hole."
Had not heard this new internet rumor until now.
Worst part is once it takes hold on the internet, this question will keep coming up for decades....
You sure he actually meant that or was it more like guys are pulling the machine around on the shop floor by the torch ?
gallantsculpture
- gallantsculpture
ya no he was very specific about the idea that pulling welds along is the culprit in causing miro arcs down in the gun. I had a pretty good sense it was not accurate, like one of the other posters pointed out how would the machine know which direction the operator was traveling.
Looking at the equipment there are times walking up to the machine where the cup is very close to the tip, its sort of off center in the cup orifice. Im thinking that its more likely there are times where the operator lets the cup touch the tip and it shunts out against the grounded work and thats whats causing the arcs in the gun. My thought at least.
Anyways thanks for the input all.
