Metal deposition rates go up but so does the power requirements and cost of the machine. Not necessarily a drawback, but not in everyone’s cost benefit price range or need.
OK, I see what you're saying. So the con is that it's impossible if you don't have the right machine. Yeah, there's really no work-around for that.
I have a Millermatic 255 coming next week and I've been scrambling to get everything set up. There are so many degrees of freedom that it's difficult to make decisions and get things ordered. Lack of experience is a factor! But if I limit myself to spray, it simplifies the situation.
Thanks for the input.
Why limit yourself to spray if that machine is capable of pulsed-spray? You can just use one gas for all your steel needs, and you're not limited to F/H positioning.ntm wrote:OK, I see what you're saying. So the con is that it's impossible if you don't have the right machine. Yeah, there's really no work-around for that.
I read that to mean he would be eliminating short-circuit and only using spray/pulse spray since the overall title was just "cons of spray transfer" rather than "cons of pulse spray transfer".....maybe I missed something.Oscar wrote: Why limit yourself to spray if that machine is capable of pulsed-spray? You can just use one gas for all your steel needs, and you're not limited to F/H positioning.
Miller Millermatic 350P
Hobart Champion Elite
Everlast PowerTIG 210EXT
That's right. There's lots of information about short-circuit and plenty of comparisons on the information superhighway. Most of that content is designed for hobby folk, so it focuses on light-duty machines and thin metal. I think the Superior Welding podcast is the only place I've heard mention of spray being the norm.G-ManBart wrote:I read that to mean he would be eliminating short-circuit and only using spray/pulse spray since the overall title was just "cons of spray transfer" rather than "cons of pulse spray transfer".....maybe I missed something.Oscar wrote: Why limit yourself to spray if that machine is capable of pulsed-spray? You can just use one gas for all your steel needs, and you're not limited to F/H positioning.
Thanks for the advice.
Buy 90/10 gas and 0.035 wire and you really don't have to limit yourself to spray or pulse spray. The machine has settings for short circuit transfer and pulsed spray MIG transfer that will both work with 90/10 gas and 0.035 ER70-s6 wire. According to the manual, on short circuit, the 0.035 wire is good down to 20 gauge steel, same as the 0.030 wire. It is good down to 18 gauge on pulsed MIG. On the high end, they are both good up to 1/2 inch material.I have a Millermatic 255 coming next week and I've been scrambling to get everything set up. There are so many degrees of freedom that it's difficult to make decisions and get things ordered. Lack of experience is a factor! But if I limit myself to spray, it simplifies the situation.
Multimatic 255
ntm,
One "con" of spray transfer is it can cause serious warpage if not handled right. Go too slow and it will put too much heat input into the part and can warp it pretty bad. Of course spray might not be the best for sheet metal applications. It really depends on what you are doing with spray transfer.
-Jonathan Lewis
-Jonathan Lewis
johnkruton
- johnkruton
I have this exact setup Millermatic 255, 90/10 and .035 ER70-s6 wire. I wanted your advice (noob hobbyist) on tack welding 1/4” to 1/4”. I’m assembling my certiflat fab block 30x30. My prior beginner welds are definitely holding my little plasma table casters on as I used 1/4” plate with 1/4” plate triangle used as a support. I got to see a beautiful spray transfer shot as I was welding towards me on my bench. Was very exciting for a noob. So the issue I’m having is confidence in settings. The auto set and pulse mig puts so much metal down I’m burning back and/or making a mess. (Missing my fillet as it pushes me off my weld) I’m fine just using short circuit and I could switch gas to 75/25. I was fine making “Fido’s butt” on my home gamer casters but with $1000 table that I want to assemble the best I’m looking for others who’ve done more than me. Any suggestions on settings and tips ? That 255 has a monster nozzle compared to my LE Mp210 and I wondered if my CFH should be more than 20.Louie1961 wrote:Buy 90/10 gas and 0.035 wire and you really don't have to limit yourself to spray or pulse spray. The machine has settings for short circuit transfer and pulsed spray MIG transfer that will both work with 90/10 gas and 0.035 ER70-s6 wire. According to the manual, on short circuit, the 0.035 wire is good down to 20 gauge steel, same as the 0.030 wire. It is good down to 18 gauge on pulsed MIG. On the high end, they are both good up to 1/2 inch material.I have a Millermatic 255 coming next week and I've been scrambling to get everything set up. There are so many degrees of freedom that it's difficult to make decisions and get things ordered. Lack of experience is a factor! But if I limit myself to spray, it simplifies the situation.
