Anybody got any preference to BRAND of .030 solid wire to be using with my Handler 140, for mild steel (mostly 1/8" to 3/16" thick, not much sheet metal).
Using 75/25 mix, and wondered if plain ol' Harbor Freight .030 spools are adequate, or Miller or Lincoln brand are somehow better quality?
thanks
Unless you are required to use a specific wire to meet certain classifications, I would use the Harbor Freight wire. If you are using it for just hobby welding, it will work fine. Although you might want to try other brands. You may like the characteristics of other brands of wires. In that regard, they are different. It will come down to what appeals to you.
I would recommend an ER70S-6.
By the way, where are you in NE Ohio ??
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
About an hour away. Not that far.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
