My shop's hiring... Slidell, LA
Posted: Fri Nov 18, 2016 7:37 pm
Bringing it back to the top, because we still need more people! Message me for the contact information.
I cut and pasted something I posted previously, but we're hiring again, and likely more than one:
There is now a job available in Slidell.
The company is Elite Cryogenics, and is where I work.
The most basic requirements are TIG on SS pipe, and MIG on carbon/stainless structure, and mechanical aptitude.
Additional skills that will make a standout candidate include pipefitting, fabrication, instrument fitting, and electrical. Not all (or any) are required, but each is a plus.
Steve
Re: My shop's hiring... Slidell, LA
Posted: Fri Jan 06, 2017 1:12 pm
by Olivero
After seeing the type of work your doing, if I was in LA, I might just consider it
Posted: Sat Jan 07, 2017 1:38 am
Olivero wrote:After seeing the type of work your doing, if I was in LA, I might just consider it
We're still trying to hire, so if you know someone in my area... Three no-shows in a row for a weld test... Must be padding that unemployment. That's sad, since unemployment here is a weak check.
Posted: Sat Jan 07, 2017 5:01 pm
by Ryan_82
What kind of weld test is it Otto?
Posted: Sat Jan 07, 2017 7:50 pm
Ryan_82 wrote:What kind of weld test is it Otto?
It's a pretty simple "Does he know what he's doing?" test, judged visually. There's a MIG coupon, welding a 1" stub of 2" scd, 10 pipe to a plate, inside and out. There's a simple Tee joint, 1/4", TIG, and a 1 1/2" TIG pipe weld, scd. 10, roll-out OK. All material is 304 SS.
If you can set the machine, do a decent root and cap, demonstrate you understand back-purge, and prep your coupons yourself, it's all good. We will work with and develop welders with these basic skills.
Keep in mind, this is not a welding-only job.
Posted: Thu May 11, 2017 7:04 pm
STILL hiring. We're up to 17 now, starting with five last year. Too damn busy to keep up, but "busy" is a good problem to have.
We're flush with mechanics, so mostly looking for another welder (Mechanical skills still a plus, as we're not a production shop and there are times with no welding to do). Personally, I want someone who can pass x-ray on a 2" sch. 40 304SS pipe in 6G, so I'm not the only code welder here.
Steve
Posted: Sun May 14, 2017 3:16 pm
by djrockytharp
Otto Nobedder wrote:STILL hiring. We're up to 17 now, starting with five last year. Too damn busy to keep up, but "busy" is a good problem to have.
Steve
Hey man I have around 6 years of tig and mig experience. and about 4 with stick and 2 with flux. We weld mostly 308 or 316 16 and 11 guage sheet with some carbon c channel I weld with mig. I have welded stainless, carbon, aluminum, inconel, hastealloy x, and have experience with fabrication equipment, forklifts, overhead cranes, and I am mechanically inclined. I don't have a tong of pipe experience but I am a quick learner and I'm confident I could pass a 6g pipe test with little practice. Let me know if you would like to see my resume. I'm looking to get into pipe and broaden my skill set.
Posted: Sun May 14, 2017 4:18 pm
Hi, Rocky,
16 and 11 ga. puts you right in the thick of much of the TIG work we have. Even the pipe is mostly sch. 5 and 10. Aluminum TIG is a plus, also!
The 6g isn't required, though it's good to have as a goal. It's just something on my personal wish list. The pipe weld test allows roll-out, and is visual only. More of a basic skills assessment than any actual weld test I've ever taken. I replied to your PM.
Steve
Posted: Tue Aug 29, 2017 7:35 pm
Bump...
