Anarchy61187
- Anarchy61187
Got a call at work the other day from an operator asking for his frost bucket. There's no frost and now I'm baffled by it, but this guy knows his equipment and has been a dirt worker since Moby dick was a minnow, he says wait till you get here you'll get a laugh. This is what I pull up to...
- 20180419_203730.jpg (117.32 KiB) Viewed 2269 times
Shopmaster 300
Hf 251 PC300 Wp-17 torch
S22p
Airco wasp IIIe
Aead 200le blue charge
Spectrum 3080 50 foot torch
A few grinders
A couple O/A torches
S22p
Airco wasp IIIe
A few grinders
Anarchy61187
- Anarchy61187
Some heating, prying and beating it's stuck together
- 20180418_152116.jpg (58.92 KiB) Viewed 2260 times
Shopmaster 300
S22p
Airco wasp IIIe
A few grinders
S22p
Airco wasp IIIe
A few grinders
Anarchy61187
- Anarchy61187
Some carbon arc gouging and welding the sides back
- 20180418_152130.jpg (48.8 KiB) Viewed 2258 times
Shopmaster 300
S22p
Airco wasp IIIe
A few grinders
S22p
Airco wasp IIIe
A few grinders
Anarchy61187
- Anarchy61187
You can never have too much reinforcement
- 20180419_010151.jpg (57.01 KiB) Viewed 2257 times
- 20180419_080943.jpg (62.41 KiB) Viewed 2257 times
- 20180419_080955.jpg (60.74 KiB) Viewed 2257 times
- 20180419_081002.jpg (56.94 KiB) Viewed 2257 times
Shopmaster 300
S22p
Airco wasp IIIe
A few grinders
S22p
Airco wasp IIIe
A few grinders
That was my first thought. Did he let you use the backhoe to bend it back? I’ve done some pretty precise restraightening work with a D6 CatFranz© wrote:Where is the picture of what won the argument with the bucket?
Was he gentleman enough to use the machine to bend things back for you after you warmed them up?
Anarchy61187
- Anarchy61187
I was welding the reinforcements in while he was still digging. I pinned the bucket down with a mini excavator, bent it back with a big pipe wrench and a 8 foot cheater.
That bucket was about 4 years old and a lot of hours on it with no type of hardfacing, just wore paper thin and he hit a rock. Just another day playing with dirt.
Shopmaster 300
S22p
Airco wasp IIIe
A few grinders
S22p
Airco wasp IIIe
A few grinders
Went back that easy it wasn't a bucket, it was a pattern for a bucket.
Them jobs used to be real fun back in the 60s when we worked on cable machines. Decent operator would generally bang it back into shape for you if he had something hard to hit it against. Really good ones would call as soon as the wear beads wore down to the bucket itself.
Farmwelding
- Farmwelding
That’s a precision straightening tool there. Especially if you got the winch going as well. You can push and pull.JayWal wrote:That was my first thought. Did he let you use the backhoe to bend it back? I’ve done some pretty precise restraightening work with a D6 CatFranz© wrote:Where is the picture of what won the argument with the bucket?
Instagram: @farmwelding
Nick
Nick
If you’re a fellow farmer I assume you know how a harrow works. Was doing the headlands and didn’t see a drainage culvert in the tall ditch grass and hit it with the outside tire at 10 mph. Bent the main 8x8 beam but surprisingly the cable or cable pins didn’t give. Welded the tire bracket back on and a little nudge with the Cat and it was good to go.Farmwelding wrote:That’s a precision straightening tool there. Especially if you got the winch going as well. You can push and pull.JayWal wrote:That was my first thought. Did he let you use the backhoe to bend it back? I’ve done some pretty precise restraightening work with a D6 CatFranz© wrote:Where is the picture of what won the argument with the bucket?
