Gar
  • Gar
  • New Member
    Tue Aug 07, 2012 11:04 pm
So I decided to make my own welding table. After searching for a good table, the price was just way too high to justify the cost. I located a 1-inch plate 48"x44" on Craigslist. It was quite the task getting it home, but proved to be worth the effort.
Here is a picture of the plate before its transformation into a welding table:
Gar
  • Gar
  • New Member
Here is the plate after it was water jet cut to my specs. 48x42, rounded corners, clamping slots, lifting slots, and 4-holes so the table can be set on top of studs. I am going to mount the table to a base that will hold the table securely, but allow me to flip it should I ever desire to.
Gar
  • Gar
  • New Member
Here is the top after it was Blanchard ground on both sides, bringing it to within .005. The plate was perdy flat to begin with. I only lost 1/16 inch after both sides were Blanchard ground. -Very happy with the top so far. Will post more pics as the project progresses.
delraydella
    Mon Apr 25, 2011 7:35 pm
    Detroit, MI
Very nice finish! A Blanchard Grinder has always been on the list of things that I want. Expensive, but worth every penny!
Other Steve
RonSII
    Mon Sep 17, 2012 5:53 pm
That will make an great welding table for precision work for sure :) I don't think I could bring myself to weld on top of that it looks so perfect :D
Have you found a suitable base for it yet?
Gar
  • Gar
  • New Member
Built a frame for my welding table (3" x 3" x 3/16" square tube legs, and 4" x 2.5" x 3/16" top frame, with 2" x 2" x 1/4" ;lower frame, and a 1" top plate). She is already for my first job.
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Hey,
Thats one beautiful piece of equipment. Depending on you time, i reckon custom tables could turn a pretty penny for you.
mick
RonSII
WOW!!! It looks sharp!!! very nice indeed :D
I like the caster wheels, don't think I've seen that type before, looks like they would swivel fairly good.
Great stuff!
I notice you had the sense not to bother painting the clamp rails. I'll wager a dime it's stainless.
The hard part will be using it for the first time! If you plan to do stick or MIG on it, I'd invest in some high-quality spatter spray! :)
Gar
  • Gar
  • New Member
@RonSII,
The casters are really cool. They roll really good, swivel just fine, and are adjustable so you can raise the wheels up off the floor to level it and keep it from rolling. -They are made by Foot Master, model# GD100S (rated at 1650 pounds each). http://www.castersupply.com/NAV/leveling_casters.htm
Otto,
The clamp rails are not stainless, but that would have been a good idea. 3-in-1 Dry Lube works good at keeping the rust down, but time will tell. I plan on buying stock in anti-spatter! lol
    Tue Jun 26, 2012 8:05 pm
For keeping the rust down, I use a block of camphor in my toolbox. Just throw it in there and when it evaporates, it coats all of the tools with a very fine mist of camphor oil. I've been using this method for years.
I suppose that if you made a leather cover for your metal table and threw a block of camphor underneath the cover when the table wasn't in use, the camphor could work its magic. http://www.youtube.com/watch?v=4rvitqo7mSo
The camphor idea is a great tip! I wish I'd known that one when I worked a short tour on an oil rig. All my tools had a fine mist of rust on them. :evil:
@ Gar,
You could always paint the clamp rail, and slit a piece of rubber hose to top it with to keep from banging the paint off.
I've seen commercial tables like that go for well over $1000!
rahtreelimbs
    Mon Jun 14, 2010 10:39 pm
If you don't mind me asking..............what did it cost you to have the water jet work done and to have the precision grinding done ???
Gar
  • Gar
  • New Member
WerkSpace and Otto (Steve S), both great ideas! Thanks for sharing.
Rahtreelimbs,
The Waterjet cutting cost me $300. The Blanchard grinding was going to cost me $200 (another place quoted me $600) but when I showed up to take my plate top home and pay for the Blanchard grinding, the manager there said, “Its on the house brother.” -I was shocked! Talk about “Pay It Forward.” This man’s kindness infected me and has continued to bless others. Very cool!
Edit: Recently looked at the receipt for the water jet cutting. It was more then what I remembered it was. $365 + tax.
TamJeff
    Tue Dec 04, 2012 4:46 am
That's a beautiful thing.
Gar
  • Gar
  • New Member
Thanks man!
Goat Driver
    Wed Feb 13, 2013 9:12 am
Great table! Nice work.
gcelaya
    Tue Jul 24, 2012 1:37 pm
Gar wrote:WerkSpace and Otto (Steve S), both great ideas! Thanks for sharing.
Rahtreelimbs,
Beautiful table. I was looking to get one cut in a similar fashion. Any suggestions? what size are the slots? Any more info would be great. I have to have one pxf file made to give to the waterjet guy. Out in California it is about 95c per inch for cutting.
Gar
  • Gar
  • New Member
@ gcelaya,
Thanks! The slots at each corner are 2"x1." The slots for the clamps are .768" x 18." -You can see more here (just pause the video and zoom in to see all the specs that went into this table):
http://youtu.be/twh49LW5RTI
There are a total of three videos posted providing info on the construction of this table. The four 2"x1" slots in the corners came in real handy when it came time to pick this plate up and mount it. They also make a convenient holder for my MIG gun. If I had it to do over again, I would have had two more 18" slots cut at the opposite end of the table.
Gar
CARS
    Thu Apr 04, 2013 11:38 am
Nice table. Can you post the "blueprint" that is on the video at 10 seconds?
Christopher Rathman
Chris'
Autobody
Restoration
Service
fisher
    Thu Jan 24, 2013 3:34 am
That is just too nice, congrats
Gar
  • Gar
  • New Member
CARS wrote:Nice table. Can you post the "blueprint" that is on the video at 10 seconds?
I would if I still had it brother. Sorry!
Gar
