Page 2 of 2
Re: Various welding projects
Posted: Mon Apr 06, 2015 7:30 pm
by Retroweld
Editing my post. Sorry was not trying to hijack this thread. I should have read it clearly before I posted pictures of a couple of "my" projects. Pics = deleted.
Lets start over.... I love that stool. Nice work! I wish I could do that.
Posted: Wed Apr 08, 2015 9:10 am
by AndersK
No worries mate, I just kept mine in a single project thread to find it easier. Dont mind at all if anybody posts anything else.
Thanks for the stool comnent. As I use to say, if I can do it so can you.
Just some planning, patience and simple tools needed. Even made this with a broken toe, steel toed shoes was the most comfortable to wear at that time so why not doing something fun to forget the pain
Posted: Wed Apr 08, 2015 4:32 pm
by AndersK
More tank work tonight. Welded a 316 1/4" BSP fitting.
- IMG_201504084469.jpg (42.02 KiB) Viewed 4137 times
- IMG_2015040838202.jpg (33.05 KiB) Viewed 4137 times
Posted: Wed Apr 08, 2015 4:51 pm
by exnailpounder
Hey Anders! I'm curious about your settings. I do a good bit of welding on beer kegs for homebrewers lately so I weld alot of thick fittings to 18ga.SS. What were you running?
Posted: Thu Apr 09, 2015 12:43 am
by AndersK
Sheet is 1,5 mm
Using a pedal, max 45 amps
1,6 mm 2% thoriated
Gaslens with #4 cup
1 mm 316 filler.
I start with the arc focused on the fitting. When it gets wet, angle down and start adding filler when sheet and fitting start to fuse together.
Posted: Thu Apr 09, 2015 2:40 pm
by AndersK
Jeff, do you back purge those kegs when welding the fittings?
Posted: Thu Apr 09, 2015 8:14 pm
by exnailpounder
AndersK wrote:Jeff, do you back purge those kegs when welding the fittings?
I do. I bought an argon bottle just for that purpose. I have made various purge boxes for sparge tanks and HLTs ( kegs with the top cut out) and have a nice setup for intact kegs. Been working out great. Welding thick to thin can be tricky...need to move fast but stainless welds so nice is has gotten easy. I love welding stainless. Your work looks nice.
Posted: Sat Jan 30, 2016 5:10 pm
by AndersK
Had an idea for a work light I had to get out of my head.
Made it from aluminum and steel. It has a 5,5W LED light in it and is fully adjustable in all directions
- IMG_20160127_51490.jpg (51.5 KiB) Viewed 4207 times
- IMG_20160127_27168.jpg (28.24 KiB) Viewed 4207 times
Some welding content
- IMG_20160130_1258.jpg (33.35 KiB) Viewed 4207 times
- IMG_20160130_13116.jpg (34.18 KiB) Viewed 4207 times
The steel parts are 0,9 mm thick, thinner at the rear dome after all hammering.
Welded with minimum of filler and then planished.
Posted: Wed Sep 27, 2017 11:28 am
by AndersK
Posted: Wed Sep 27, 2017 12:15 pm
by Wood Welder
AndersK wrote:Not any welding here, just wanted to show a box I made for my gas torches.
Made in 1,5mm aluminum with stainless handle and hatch.
Once again, I could by a cheap box but what do one learn from that?
I could have welded the lids so the rivets is just for the cool factor.
This box is awesome. I tried metal spinning on my lathe to make an 18" Venturi and it was a disaster.
Can you guide me to a video of the process to form metal like these boxes? The details are incredible.
Posted: Wed Sep 27, 2017 3:28 pm
by AndersK
The technique I use is called hammer-forming, used on both the box and the Porsche clock.
Good resources are Ron Covell, Peter Tommasini and David Gardiner among others.
Ron has a movie dedicated to hammer forming:
http://covell.biz/hammerforming-techniques/
The details on the lid are made differently though.
1. Make a die of the shape you want. Can be of metal, wood, plastic you name it.
2 Make a "sandwich" bottom-up : The Die, the sheet to form, a urethane pad or hard rubber, a thick steel plate
3 Place that sandwich in a press and squeeze.
Below is an example I made with a steel die in 0,5 mm stainless
- zoom1.jpg (52.75 KiB) Viewed 3662 times
- zoom2.jpg (55.94 KiB) Viewed 3662 times
- zoom3.jpg (235.77 KiB) Viewed 3662 times
Posted: Sun Oct 01, 2017 8:30 am
by motox
Anders
what did you use to form the letters in the steel?
Posted: Sun Oct 01, 2017 12:07 pm
by AndersK
Bench shear, jig saw and files. All hand crafted
Posted: Mon Oct 02, 2017 8:38 am
by motox
anders
then you weld the the letters to the plate?
nice job by the way!
Posted: Mon Oct 02, 2017 9:33 am
by AndersK
Yes, they are spot welded. If you zoom in you can see the darker spots.
Laser cutting would had been a lot easier but this was just a fun weekend project at a Metalmeet in Norway.
Posted: Sat Oct 07, 2017 5:08 pm
by ollie81
Looks brilliant mate, like a heavy duty flight case!
Posted: Mon Oct 09, 2017 1:05 pm
by AndersK
Thx mate.
It's been in my mind making one for sure
Posted: Sat Dec 30, 2017 3:11 pm
by AndersK
Posted: Sat Dec 30, 2017 3:23 pm
by motox
Anders
is it 3003 or 5056?
looks sharp!!
Posted: Sat Dec 30, 2017 4:36 pm
Looks real good Anders, you are quite talented!
Posted: Sun Dec 31, 2017 6:01 am
by AndersK
Thx guys
Top and bottom is 1050A 1,5mm
Shroud is 5052
Posted: Sun Dec 31, 2017 9:35 pm
by 5th Street Fab
AndersK wrote:Another box made, at least it has one weld in it....
Ya I saw this on Instagram! Nice job I like it a lot!
Sent from my XT1635-01 using Tapatalk
