Well done okkim - glad you are having some success.
Kym
- MosquitoMoto
Well, that didn't last long... I finally got the left hand thread bolts, and made threads. But the bolt just went in, but the old didn't come out. I tried in two different bolts, no success. Then I drilled the holes bigger first to 7 mm, and then to 8 mm. After that I tried to remove the remainings with a M10 tap. Some of the holes cleaned a bit, but some threads got damaged because the tap didn't go straight in. Now I'm thinking to buy Time-serts and fix those for good.
