I use a shallow grind like he pictures any time I need to do fine narrow welds on light gauge material. Everyone is entitled to there opinions, but don’t be an ass hat.
TraditionalToolworks
- TraditionalToolworks
So, you know what he was using those for?Poland308 wrote:I use a shallow grind like he pictures any time I need to do fine narrow welds on light gauge material. Everyone is entitled to there opinions, but don’t be an ass hat.
You think those are useful then?
I'm not being an @$$ hat, but please don't be an Iowa SOW.
To me it looks like bling. I wonder if those could be counterfeit tungstens???
Collector of old Iron!
Alan
Alan
I do think it’s a useful grind. When you grind to a sharp tapered point it causes the arc to be more diffused and less focused. This helps when welding thin metal. Being less focused means shallower penetration. It also makes a noticeable difference on getting your edges to wet in. (Most notable in my experience on SS). I used a grind like this just today while welding some steel parts to a SS burner head (309) on a 70 hp boiler. We rebuild the burner but had to custom make some of the parts because the manufacturer isn’t in business anymore. The burner metal was 14 gauge but the gas pipe was 3inch sch 40.
https://www.google.com/search?q=tungste ... szoSCyRC9M
https://www.youtube.com/watch?v=ZI3SyGjjbfw
https://m.youtube.com/watch?v=LTb9HLoWTWA
Thanks for those links Josh, very informative!
David
Millermatic 130
Primeweld 225
Millermatic 130
Primeweld 225
Josh,
Understood, but I don't think the majority of people are welding thin metal too often, I would classify it as the minority of the time.
I think we need to keep the question in context, not twist it out of proportion or second guess what metal is being used. I'd like to see what Oscar is welding with that tungsten, no harm in me wanting to see.
Jerry was asking a general question about sharpening tungsten. From what Jerry has posted he's not using thin metal.
I saw it as nothing more than posting bling, although Jerry took the bait with the bling as he either ordered or bought the HF grinder.![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
Alan
Alan
It doesn’t have to be on thin metal. I used a grind like that on my UA67 pipe test that’s 2in xx heavy wall, for unlimited thickness. Doesn’t mater metal or thickness.
Well, if that type of grind works for people, they should definitely use it. I've never had a reason to use a tungsten sharpened like that, so maybe it would be better to say I've never had a use for it and I find the thin point gets destroyed easily in my experience. Again, my experience is limited, I am not welding any UA67 pipe with 2" walls, I do more with .063", .093" and .125" wall tube and plate from 1/16" - 1/2" thick.Poland308 wrote:It doesn’t have to be on thin metal. I used a grind like that on my UA67 pipe test that’s 2in xx heavy wall, for unlimited thickness. Doesn’t mater metal or thickness.
BTW, in your previous post you stated you were welding 14 gauge with this, now you're welding 2" thick UA67 pipe, so is it safe to say that you are using these shallow grinds on most all of your work? Or are you just dancing around my posts to try and make me look bad? (my guess, and what I referred to being an Iowa SOW.
Alan
Alan
Can you pick up an extra bag for me David?DavidR8 wrote:I'll be at the concession getting some popcorn...
Alan
Alan
The only time I don’t use that grind is on aluminum but sometimes even then, or when I don’t have access to a good grinder ( then you just kinda get whatever you can on a 4-1/2 flap disk.
I've noticed it, but trying to be nice to you.Poland308 wrote:I can’t dance. I just dislike your constant skepticism and seaming distain for advice from others on maters you have limited experience with.
Sometimes it might be better to STFU and let me show people how stupid I am. I'm not intimidated.
I have to agree, you certainly weren't dancing very well...
Alan
Alan
This obsession with needle point tapers and specialty grinds on grinds is mostly a lot of horse hockey. I’ve seen hundreds of people weld razor blades with 1/8 tungsten and a typical 30* taper and not have so much as a burp.
I’d venture to say the average meat lover on this forum could not TIG weld the difference unless all they did was very high tolerance code work. FFS, that KaneKid Dude only swaps tungsten diameters to weld those 0.006 wall tubes, and that I can understand because he’s welding in single digit amps.
The rest of it? Malarkey. Looks cool, feel special, complete nonsense. Learn to weld FFS.
Of course it's mostly nonsense, just like Josh's response.cj737 wrote:The rest of it? Malarkey. Looks cool, feel special, complete nonsense. Learn to weld FFS.
Not long ago Josh said he uses a TechSouth at home to sharpen his tube of tungstens before he heads to work. At least that's how I remember his comment, I could be wrong. I'd love to see his tube of tungstens when he heads to work, cause I don't believe he's got them ground with that shallow of an angle. In fact, I think he's only creating this entire BS to counter me because I rub him the wrong way. That's fine, I get my personality bothers him, but I'm still calling his bluff.
So post up your tungstens Josh! Let's see those shallow grinds! Hurry, run out and regrind them so you can show your shallow points!
Look, I'm certainly not the welder that Josh is, that much I will admit. I'm here to learn, and even so I will never be as good of a welder as someone like Josh that does it every day.
But my nose is pretty good and I smell BS, so I'm calling him on it, just like I did Oscar. I'd love to see the projects Oscar's worked on with those shallow tungstens also.
Alan
Alan
kiwi2wheels
- kiwi2wheels
[quote="TraditionalToolworks"
[/quote]
Yadda, yadda, yadda, just read more, write less !
I really wish the forum had a blocking option .................
Sometimes it's getting like a f*****g kindergarten.![Rolling Eyes :roll:](./images/smilies/icon_rolleyes.gif)
![Mad :x](./images/smilies/icon_mad.gif)
I dont get the argument here...Oscars grind is not un usual, different grinds for different applications and different preferences. If all you care about is getting max life out of a tungsten so you can weld all day without sharpening, use a blunt 5/32 tungsten! If you want crisp, precise arc starts then use a sharp, smaller tungsten. You want something in between, try it! 90% of us on here are hobbyists, so try different grinds from extremely blunt to extremely sharp and see what the difference is. Then you'll see why some people prefer the grinds that they do. I'm also pretty sure most people on here, me included, will sink that tip into a weld puddle and have to resharpen anyways long before the arc actually erodes away that tip.
Who cares what he's doing with them. Besides, it's Oscar, trying out wierd stuff is literally what he does best![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
I completely agree Jay, I was originally asking why Oscar shows those when he more often than not shows a much blunter tip with very little stickout when he recommends how people should be tig welding.JayWal wrote:I dont get the argument here...Oscars grind is not un usual, different grinds for different applications and different preferences.
So why the discrepancy? That was my question.
Again, agreed, but we shouldn't say that a grind like that works for all work. Josh came in taking exception, said he uses it for thin metal, then changed to using it for 2" thick pipe. Why does his comment change like the wind?JayWal wrote:If you want crisp, precise arc starts then use a sharp, smaller tungsten.
You have sure helped a lot of people on this forum.robtg wrote:People come here to learn but they are the ones doing all the talking. Just an observation.
Some just come to suck out of it what they can.
Alan
Alan
I find myself spending less and less time on this forum because of the petty squabbles and passive aggressive comments. And I find it interesting that usually without exception, there is one particular person involved every single time.
Yup...couldn't have said it better.Spartan wrote:I find myself spending less and less time on this forum because of the petty squabbles and passive aggressive comments. And I find it interesting that usually without exception, there is one particular person involved every single time.
David
Millermatic 130
Primeweld 225
Millermatic 130
Primeweld 225
av8or1
- av8or1
Wow. In other news, the small bench grinder that I ordered from HF is not only absent, but it hasn't even shipped yet. I called today to inquire further. Apparently they're behind due to the fires in CA, but the rep assured me that it will ship out "...in another day or two." By contrast, the tungstens and 3" grinder wheel that I ordered through Amazon arrived two days later, on schedule.
So. The point being that I stated that I would report back with the news on how well this ~$60 setup would work. And I will do that, but just not yet. Gotta wait on the grinder to show up from HF. Heck, I'm tempted to call the local store to see if they have it in stock and if so, just go get it there.![Very Happy :D](./images/smilies/icon_e_biggrin.gif)
