LS Customs
    Tue Feb 23, 2016 11:56 pm
with the spring in hand, i put the rest of the cooler together... i also used purple ice (like water wetter) and distilled water (180 ounces in the tank)... i was able to adjust the pressure of the setup, using the pumps adjustable valve now.. and i can tweak it a little if necessary with the valve i added... since its already there...
LS Customs
the 250 psi spring, fell back into the pump, so i took the filter out to get it out... clean that up, while i was at it...
the thinner is the appropriate spring
also put a screen over the exhaust fan, to help trap dust, or keep misc out... when the setup is sitting..
LS Customs
also added two temp gauges (inexpensive), wasnt necessary but i like to see that the setup is actually working... one on the hot side and one on the cold...
i replaced all the hose with high pressure hose... just to be safe... the clear hose is rated to approx 50 psi... but with the heat of the system, i didnt want it to be close... the reinforced hose is rated to 250 psi and is inexpensive, so was no excuse to not replace it.
LS Customs
mixed the additive into the distilled water
and filled the tank back up with the fresh "coolant" mix
LS Customs
set it on the stand, so that i could properly test it out
LS Customs
i typically practice by actually trying to make things... so making a small gas tank... the new torch, welding positioner and water cooler setup, work awesome..
i already added two 1/4" npt bungs on the bottom, one of each end, gotta add a cap/bung and two bling bungs and done with it... its not perfect, but best i can do at this time... i will polish it.... someone may purchase it and that helps to buy more materials to practice with...
LS Customs
7r-gw4BnyVc
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
LS
did you fab the tank ends or buy them?
LS Customs wrote:adding a bolt on handle right behind the welder and one more strap (on the handle) toward the top third of the bottle, though it is very secure... next refill, im going to sell this cylinder to the gas supply and buy the next size up.. and will want the extra strap higher up for that cylinder
How do you guys get the stubbies out from the rod holder tubes? These are mine. :)
Very, run-of-the-mill looking...
Lo' and behold! Stubbies can no longer hide from me at the very bottom! :lol:
LS Customs
motox wrote:LS
i programmed the ones with letters, or a design in them (using fusion 360)... the dome looking ones in the video, i bought them in misc sizes from sharpe products (i think)...
but these cnc style ends, i programmed/designed in cad and they were cnc'd
LS Customs
LS Customs
LS Customs
i used one of my revolvers to program this and was to scale... these are bolt on end caps and bolt on bullets for them... a friend is building a mini bike to match one of his hot rods and i wanted to add a little bit of me to it...
but i typically program or draw the stuff out in cad and have a person with a cnc, machine the program... i am looking into getting a DIY style cnc or trying to make one... as i am not making money doing this stuff, it is hard to justify spending the money... but im working on it
bosulli
    Tue Apr 05, 2016 9:40 am
    Batesville, MS
Great design, and resourcing. Been looking for a water cooler concept. I will have to borrow yours. Thanks for posting it.
LS Customs
bosulli wrote:Great design, and resourcing. Been looking for a water cooler concept. I will have to borrow yours. Thanks for posting it.
thank you
LS Customs
still working awesome! works even better after the latest addition
To follow up on a thread-jack I inserted in this conversation many pages ago (I THINK it was this topic I jacked...)
During a repair to a Miller SW250DX with integrated water cooler, I found the pump is rated for 30PSI at 25GPH, which is right in the range of the potable water pump I salvaged from an RV and was the subject of my question.
LS Customs
Otto Nobedder wrote:To follow up on a thread-jack I inserted in this conversation many pages ago (I THINK it was this topic I jacked...)
i think it would work fine, i would think the flow rate set correctly is the more important thing... on my torch the max rec is 50 psi... i think mine is set to around 45-48psi at this moment and i estimated the flow rate to be about correct for the torch... havent put a meter on it... but im thinking as long as the coolant/water flowing through the torch isnt above the max psi, but is flowing the correct 1 quart per minute, it would work awesome...
MediocreDesigns
    Mon Oct 29, 2018 10:27 pm
Great info, thanks.
Did a specific parts list ever get posted for the brass fittings that were required to deal with the left hand threads? I didn't see it anywhere.
