I got out of blacksmithing as a hobby and got rid of all my gear years ago. Now I'm regretting that and would like to get back into it. When this anvil fell into my hands, I just couldn't pass it up (especially for the price asked!) Which brings me to where I am now.
As you can see, it's a mess. From what I have been able to find online, it's a Wilkinson brand from Dubley England with a wrought iron body and a hard steel face plate forge-welded on at the foundry. I can't see anything that indicates how much of the face-plate is still there, but I'm suspecting there isn't much. I found a tutorial online that teaches you how to prepare the anvil and what rods to use, but I'm not sure about quantity of rods to purchase or, really, all those little details that a neophyte welder might run into.
In this side shot, you can see what looks like a bead of weld from a previous attempt at repair. Not too pretty, and it looks like maybe the face plate is bent down into the chipped wrought iron body a bit. Maybe an eighth left over?
The tutorial, found here http://www.iforgeiron.com/topic/16052-w ... -approach/, states to bring the anvil up to 400° and lay down bead after bead using "Stoody 2110 (or equal) 3/16" rod." Once you've sufficiently built up the face of the anvil, I can bury it in vermiculite till cool and then grind the face to shape.
Sounds real easy! What could possibly go wrong?
So far, as I understand it, I'm going to burn off the paint using my propane weed-burner-of-Doom! Then I'm going to take my angle grinder to it and get rid of that "repair" as well as all the sharp edges around the various bad spots. Once down to good metal, I'm going to heat the entire anvil up to 400° and then start laying down bead until I build up sufficient thickness in what's now the new face plate. I'm thinking a layer measuring .500" thick.
Does that sound right? Sounds relatively easy and a fairly simple project for a new welder to at least get practice making nice beads. I can't really ruin this anvil any more than it already is, can I? It's very round, as is, and it came cheap..... so I don't guess it would be that great a loss if I totally screw the pooch on it. But I'd rather have the project all fleshed out before even trying to weld on it.
How many pounds of rod would you expect to need to weld a half-inch thick layer on top of a 4"x14" anvil table? Is a half-inch too thick? Maybe stick to an eighth? A quarter? When you say "Stoody 2110... or equal" what does that mean? A ten-pound box of Stoody 2110 CTD is a bit pricey, but still not too bad if I only need ten pounds. If I need three boxes, I could practically buy a new anvil for that same money. Is there an alternative hard-facing rod that might be as good or better? Anything I'm not seeing or planning on? Would you consider this too much of a project for a beginner welder?
I'll look forward to hearing your thoughts. Thanks for your time.
