Louie1961 wrote:You read way too much into my statement. All I said and all I meant was I wonder how it runs 6011?
Well, the very first pic in the OP was 6011 bead on the edge of a 1/2" mild steel plate.
Louie1961 wrote:I actually hope it runs 6011 like a champ, it will make that an even better welder.
It ran it find for me. I mentioned I ran both 3/32" and 1/8", the 3/32" was Forney in the yellow plastic box, and the 1/8" was Lincoln in the 1 1b. clear plastic, Fleetweld 180-RSP, either from Home Depot or OSH when they were in business. The Forney yellow plastic box came from OSH, it's made in Mexico. The Fleetweld runs better, IMO, but 6011 is harsher than 7018.
Louie1961 wrote:Again, you read way, way to much into my brief commentary. I am not a brand snob. There is one company I won't do business with anymore because of the way I personally was treated. But beyond that, buy what you want, its your money. I wish you nothing but the best.
That's totally fair, maybe that company is AHP, I don't know...I've been pretty vocal about not being treated with decency by the green weenie crew at Everlast, and I will not buy another welder from them, nor will I buy AHP as it's the same people. I knew that Oleg had a big share in the company, but found out the other share is owned by his wife...
So look Louie, I wasn't trying to not run 6010, and I did run a fair amount of 6011, I had no trouble starting it, it burned pretty nice. I was running 92 amps on the 1/8" Fleetweld and 72 amps on the 3/32" Forney, maybe could have gone down slightly on the Forney, but it ran it pretty decently to me. I'm not a great stick welder and haven't welded a bead of stick in about 2 years.
I would even say that my Primeweld runs 6011 as good or better than my green weenie i-Tig 201 which has an Arc Force knob.
Both 3/32" and 1/8" 7018 was Lincoln Excalibur, I just favor and like that rod for 7018. I do have some 1/16" Hobart 7018 but didn't try it. I do have a pretty good selection of stick rods, but most are only 1 lb. packs. I only buy 10 lb. of Excalibur because that's the smallest they sell it in. I'm not a stick electrode hoarder. I probably have more tig filler.
