hi I think they will ask us to quarantine again for the epidemic, so I am preparing for the new emergency.
I would like to make homemade barbells and dumbells to work out a small gym corner a barbell bench a pull-up bar, any suggestions? I would like to use materials that I can recycle in landfills or at a junkyard or workshops, any suggestions? steel axles flywheels worn brake discs to be cast and melted in steel mills or similar. let me know, thanks.
Bls repair
- Bls repair
Buckets of sand, gallon jugs of water or sand, look for stuff you have laying around. You don’t have to get fancy ,your just going to pick things up and put them down.
[https://youtu.be/vJV6UWTAekE][/youtube]
https://youtu.be/44sB_sELhHE
https://youtu.be/PBvrZof1AQo
https://youtu.be/EForx7x6OKQ
https://youtu.be/0zHM8pgdtV4
thank you all
thank you all
i am what i am
