jwmacawful
- jwmacawful
a couple months ago a full roll off container got away from the truck as it was being hoisted and mangled the existing compactor stop which consisted of a 4 1/2 inch by 6 inch angle iron 92 inch long. i salvaged 2 pieces of this angle and cut them 9 inches long and welded a 4 inch long piece of 4" H beam as shown with 7018 then welded both to the steel plates that form the pad.
- PA070125.JPG (23.15 KiB) Viewed 1206 times
Follow da blue light
- Follow da blue light
Was it a bulk bin that sits in front of the compactor that got away?
A cuppla jobs ago I used to work for a waste disposal company and all the bulk bins were let down onto rails that were dyna bolted to the concrete, no chance of them getting away as there was a HUGE stop welded to the end on the rail.
jwmacawful
- jwmacawful
the container and compactor are one unit and it destroyed the stop when it got loose as it was being hauled onto the truck. i'm guessing this is a pretty common situation.Follow da blue light wrote:Was it a bulk bin that sits in front of the compactor that got away?
