First up I wanted to build a welding bench that let me clamp anyware and every ware
So I come up with using I beams that can be clamped anyware on the table
So I made the base
Than I cut up some I beams and mounted angle on the so the could slide and it was done
Works well to
Next up I need a bender to make frame mods on my bikes , so I searched the inter webs for some full sized plans , got the printed out , cut the plans out than contact cemented it onto the steel. Than transferred the plans with a centre punch .
Than attacked them with the gas axe , than finished with a file and sanding
That's it for now more later on
