    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
I have been wanting to build a round welding table for some time. I got this 38" diameter 1/2" plate drop from another project and thought I would put it to good use. This is a table for my garage and depending on how I like it, I might add one to the shop as well. The best part of this build is everything you see is scrap so I have $0 in it! My wife likes that point as well.
The legs are some 2"x4"x 1/8" rectangle tube @ 36" tall and the bars are 1/2".
What I like most about this table is the ability to weld on pipe. I will be able to weld around the whole circumference with out stopping. Maybe you can get some ideas from this table as well.
38 inch plate top.JPG (85.08 KiB) Viewed 3732 times
38 inch bottom.JPG (98.13 KiB) Viewed 3732 times
38 inch table top vise.JPG (122.21 KiB) Viewed 3732 times
    Wed Oct 23, 2013 3:30 pm
    Palmer AK
I like it. ;)
~John
TamJeff
    Tue Dec 04, 2012 4:46 am
Seems like a good use for a round drop. I would find a use for it and it just looks cool.
    Fri Mar 15, 2013 10:55 am
    Philippines
That looks cool, not everyone uses a round top for a welding table ! :D ;) I like it too !
    Palmer AK
I guess now, your tools are unable to roll of the corner of your table.... :lol:
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
i like that it takes up less room and plenty
of clamping area
nice idea
weldguy53
    Tue Nov 11, 2014 5:05 pm
I like it : :D
Wes917
    Fri Oct 25, 2013 11:45 pm
Looks god from here and the price is right. I would probably add a through hole in the center so all it would take is a threaded rod, a plate, and a nut and you have a universal clamp. Nice work.
    Eddy, TX
Wes917 wrote:Looks god from here and the price is right. I would probably add a through hole in the center so all it would take is a threaded rod, a plate, and a nut and you have a universal clamp. Nice work.
Now there is a idea I just might use. I was supposed to order a bearing set up that would support a ground and have a lazy susan type of top so I can rotate the table for the shop. Probably ought to get that ordered. I have 24 of these drops so the ideas are endless.
Wes917
Man that's a good amount of drops. With those extras I would probably build a turntable out of at least one, probably two once nailing the design down
    Eddy, TX
Well, I had 24 drops. I have been giving them away to others needing steel or wanting to make a table like this one. Not sure how many are left. I have been telling my wife I would like to make welding tables and see how well they would go on Craigslist. Who knows.
Sounds like good "evening work". If you chronicle it, would the title be, "Nights of the Round Table?"
    Sat Jul 06, 2013 11:16 am
As my Dad used to say, "Ten Thousand comedians out of work and you're trying to be funny". :)
    Eddy, TX
Steve and Len,
:lol: :lol: :lol:
RagTopTA
    Thu Feb 25, 2016 6:51 pm
Heres some round welding tables I made. We use them every day in different ways. The small clampable vise sure works great on all the tables.
http://imgur.com/w5mKfEc
http://imgur.com/C6ueniv
