Page 1 of 2
DIY Cutting Log Stand
Posted: Fri Apr 04, 2014 3:57 am
by roberts56
Well most if not all materials used where scraps or excess from other projects stocked in my garage. Using 2" GI pipes for the main body and some 1" GI pipes as well plus others. Decided to make this project to make cutting some logs for firewood easier. I have seen different variations on YouTube but decided instead of remaking or copying their designs, I'll make my own version and see how it will come out. Ok, plans were not set on paper, I just started the project with a clear mind of what I wanted to achieve, adding things here and there as it progresses.
Sorry for there were no pics taken during the initial stages but manage to take some during the middle and last stages up to the completion of the project.
And this is somehow the cutting stand will come out with some of its accessories to be welded.
THE INITIAL ACCESSORIES TO BE USED:
The two 6" rubber wheels with its axles.
The movable clamping claws.
Re: DIY Cutting Log Stand
Posted: Fri Apr 04, 2014 4:14 am
by roberts56
Posted: Fri Apr 04, 2014 4:35 am
by roberts56
Posted: Fri Apr 04, 2014 4:48 am
by roberts56
Posted: Fri Apr 04, 2014 5:05 am
by roberts56
Posted: Fri Apr 04, 2014 5:24 am
by roberts56
Made and added these two metal buckets where I will put my fuel/oil mix.
Also added two 3/16" plate behind as a stopper for the logs plus also expanded and extended the lap by welding scrap 16 mm corrugated steel bars.
Made a rounded steel knob and welded it on the head of the bolt to easily loosen or tightening the hold on the guide bar.
Added a D-Handle welded on a piece of 1 1/4" GI pipe, then added two stainless steel bolts and nuts to secure it on the upper portion of the vertical 1" GI pipe.
Posted: Fri Apr 04, 2014 5:36 am
by roberts56
Posted: Fri Apr 04, 2014 6:04 am
Hey,
That is a spectacular job. Lots of smart thinking and trial and error. I have never seen nuts welded on like that, were you tought that or just do it? Also i disagree with the fuel oil mix in the holders, they should be for beer. Lol (for after cutting of course)
Posted: Fri Apr 04, 2014 8:21 am
by roberts56
roberts56 wrote:
[/url]
Made this one too as sort of a holster for my small chainsaw.
And this bolt will lock and secure the guide bar inside the holster.
OH, if you are referring to this kind of welds on the nut, so sorry about the ugly weld beads and how it was welded, I know its so bad but then in the final stages, it has been grinded and re-welded again before the final painting. I just have this habit sometimes of playing around with weld bead applications, trying to find out if it will work or not. Me? well just a self taught hobby welder and still trying hard to master stick welding. Well about those fuel/oil mix canisters, just live 'em there, I'll just have a separate cooler with some ice cold beer around or nearby. LOL
Thanks mike !
Posted: Fri Apr 04, 2014 1:33 pm
by AKweldshop
Looks awesome!
~John
Posted: Fri Apr 04, 2014 3:22 pm
by GreinTime
He's not critiquing them man, just curious as to what the motivation to run the stringers out from the corners of the nut
Sent from my DROID RAZR using Tapatalk
Posted: Fri Apr 04, 2014 6:54 pm
by paul_s
A really great looking job. It brings back some memories of my wood cutting days.
Posted: Fri Apr 04, 2014 10:12 pm
by Superiorwelding
Looks good. I especially like the color contrast. I was also wondering about the nuts, can't say I have ever seen them welded that way...looks like a little gusset. You may have just started a new trend
Posted: Sat Apr 05, 2014 2:25 am
Good stuff mate. Keep it up.
Posted: Sat Apr 05, 2014 5:24 am
by Bill Beauregard
Nice cup holders.
Posted: Sat Apr 05, 2014 7:36 am
by roberts56
Thanks all guys for your kind words and encouragement. Whether with some criticism or none, that's ok with me, it might help improve my welds.
Posted: Sat Apr 05, 2014 6:53 pm
by RichardH
Nice work! It's impressive to see the difference paint makes. The 2-color job makes it look sharp!
Posted: Sun Apr 06, 2014 2:05 am
by tradetek
The finished product looks good, but I'm curious what the balance feels like at the rear axle? Is it easy to tip it backwards?
Also, what way are you planning to cut logs on it? Cutting piece hanging off the end, or similar to the sample piece you put up and then cutting down or sideways? If so, I'd be a bit concerned about how close the metal cross members are going to be to the chainsaw blade as it breaks through the end of the cut.
Looks like a good build though.
Bill
Posted: Sun Apr 06, 2014 4:24 am
by roberts56
RichardH wrote:Nice work! It's impressive to see the difference paint makes. The 2-color job makes it look sharp!
Thanks man, glad you like it too! Yes I myself am ecstatic about the final outcome of the color scheme used.
Showed it to a friend recently and he thought its a newly purchased cutting stand from a home depot.
Posted: Sun Apr 06, 2014 4:46 am
by roberts56
@ Hey tradetek,
No problem whatsoever with balance specially concerning the rear axle coz the front side is a bit heavy with the addition of the two 30" long movable pipes, plus of course it is tilted towards the front.
When it comes to log cutting, it will simply be as cross cutting from the right side to a desired length, say 20" per cut up to the Y supporting the log with some 3" clearance so I don't think the chainsaw bar will in any way get in contact with any metal parts.
Thanks and do appreciate for the concerns !
Posted: Sun Apr 06, 2014 8:56 am
by tradetek
Makes sense. I was recently cleaning some metal with a knotted wire wheel in my angle grinder. It clipped the cord and ripped it in half while wrapping the cord up tight against the spindle. I'd hate to see what damage could happen if a chainsaw were to get through a log hit a metal bar and then start bouncing between wood and metal while your reactions were either yank it out or drop it. Either way, I was envisioning a potential disaster
Bill
Posted: Tue Feb 24, 2015 1:26 am
by AlexG
Posted: Wed Feb 25, 2015 4:09 pm
by exnailpounder
Where's the cooler
Very nice!
Posted: Sat Mar 14, 2015 9:22 pm
by Hvacr
I know this thread is a year old but if the OP is still around wanted to say congrats on ingenuity and color scheme.
Posted: Mon Mar 16, 2015 6:34 pm
by massacre
I wish sometimes we had pics of these in action.
I'm probably dumb but I can't envision how they are supposed to work! lol
Sorry.
