Well, it took a while and a couple revisions, but I finished my circle guide for my Powermax 45. Probably more HD than needed, but I always seem to over build!
I need to design a guide wheel, the drag tip is not ideal for a smooth cut. The two handed approach, with one hand on the end of the rod, works okay. Cleaning the surface helps too!
But the swing rod may be a little spindly for rest of it
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
Thanks,
Everything was ordered from McMaster-Carr .... probably spent $50 with a couple revisions!
Should be easy enough for the center pin, but I wanted the magnet to help keep the torch vertical that is the main reason for the needle bearing holding the torch.
I like that. I built my own tig torch holder with one of those magnets and some scrap. I literally got done doing a cut out and looked at a couple pieces and thought that would work for a tig torch holder welded them and there it is. I didn't even finish it up. It looks nasty but works great.
Matt
