I noticed my MIG welder losing gas fairly quickly so I checked for gas leaks using soap/water. Lots of bubbles coming from where the regulator threads into my tank. Is this normal? Do most people use teflon tape at this connection to create a better seal? Thanks.
- air bubbles.jpg (3.24 MiB) Viewed 22563 times
Jack Ryan
- Jack Ryan
Tape is for tapered connections, it won't help there. (OK, it might help a bit but it's the wrong approach).
Take the regulator off and check the nipple and the seat for damage or dirt. It is a brass connection and shouldn't be tightened hard.
Have you used the regulator before? Did it leak after a cylinder change?
Jack
Jack
Jack Ryan
- Jack Ryan
Jack Ryan
- Jack Ryan
Yes, and some are just brass with no O-ring so it is even more important to have good surfaces. As brass is soft it is a bit forgiving but that also means you don't over tighten it.
Jack
Jack Ryan
- Jack Ryan
