I have built around 15 different stands out of 1" or 1.5" 11gauge angle and I have done both coped and mitered, and for the strength of the 11 gauge (1/8") material I don't find that the extra time to cope the material is worth it. I use a carbide chop saw to miter the corners. On the horizontal side of the angle I normally weld on the outside, just add a bevel about 80% the thickness of the material and fill with the weld bead. This makes a clean full penetration weld that you can quickly and easily grind flat. For the vertical portion, if there isn't anything that needs to fit right into the corner (not the case for you) I just run a bead up the inside corner. If I have something tight fitting to the inside, I will either leave a 1/16" gap or put a small chamfer on those edges as well and run the bead up the outside, which will again be easy to clean up.
As is mentioned before, I believe that the cope typically is a stronger joint, but in you configuration with the size material that you have I don't see a real advantage to the extra time and effort.
Good Luck with the project.
R.J.
That's what I was thinking. I'm all for "over engineering" but an extra 5 min per cut on a non structural piece seemed like overkill. I'll definitely practice some cuts and welds on scrap first but thank you to everyone for the great input.airrj wrote:I have built around 15 different stands out of 1" or 1.5" 11gauge angle and I have done both coped and mitered, and for the strength of the 11 gauge (1/8") material I don't find that the extra time to cope the material is worth it. I use a carbide chop saw to miter the corners. On the horizontal side of the angle I normally weld on the outside, just add a bevel about 80% the thickness of the material and fill with the weld bead. This makes a clean full penetration weld that you can quickly and easily grind flat. For the vertical portion, if there isn't anything that needs to fit right into the corner (not the case for you) I just run a bead up the inside corner. If I have something tight fitting to the inside, I will either leave a 1/16" gap or put a small chamfer on those edges as well and run the bead up the outside, which will again be easy to clean up.
R.J.
Hobbyist MIG welder with 75/25 gas on a Lincoln SP-140 in my garage/workshop/gym/storage space. Very new and still learning.
"Service is the rent you pay for room on this earth" - Shirley Chisholm
I recently built a stand for my band saw, and decided on doing miters. I built a small test piece, and after cutting the miters I ground the sharp edges like recommended above which gave a nice area to fill with weld.airrj wrote:... just add a bevel about 80% the thickness of the material and fill with the weld bead. This makes a clean full penetration weld that you can quickly and easily grind flat.
- IMG_20170406_124336466.jpg (40.21 KiB) Viewed 4143 times
- small square.jpg (39.89 KiB) Viewed 4143 times
AdVirMachina
- AdVirMachina
How do you cope a square tube? I'm not seeing how that would work.exnailpounder wrote:I used to woodwork some myself (and carpenter work..hence my screen name) and mitering is customary in that profession but in metal, the idea is usually to make something as strong as possible. You can get much more weld bead on a coped angle or box tubing than you can mitering. Strength might not be a priority for your project but IMO every project should be as strong as it can be made. I also happen to think coped looks better.Josh MacD wrote:As a lifelong woodworker that runs against everything I know, but I'm still learning the rules around here.exnailpounder wrote: Mitering looks amateurish.
Sent from my HTCONE using Tapatalk
Coping square tube is rare; The nature of square tubing reduces the benefit of coping over a miter unless the loading is through torque. The time involved in properly coping square (or rectangular) tube is significant, as well.AdVirMachina wrote: How do you cope a square tube? I'm not seeing how that would work.
I attempted to draw a square tube cope profile, but I've had too much food and way too much beer to pull it off. I'll attempt it again tomorrow right after work, if no one beats me to it.
Steve
I can make a cope on box tube or angle in 30 seconds with my porta-band. I've seen guys try to use a chop saw to miter and when that blade gets flexing it might be a 45..or not. My cold saw works great for mitering but at $100 a blade, I save it for more important cuts. I bet I can cope a piece as fast as anyone can miter one. The porta-band RULES!Otto Nobedder wrote:Coping square tube is rare; The nature of square tubing reduces the benefit of coping over a miter unless the loading is through torque. The time involved in properly coping square (or rectangular) tube is significant, as well.AdVirMachina wrote: How do you cope a square tube? I'm not seeing how that would work.
Steve
- 20170503_073634.jpg (46.23 KiB) Viewed 4098 times
Thanks to Jeff, I don't have to draw it. That's an excellent example. One time-consuming variation (which I had in mind when calling the task time-consuming) is to do the reverse side opposite the face side, so the butt is vertical, where on the face side it's horizontal. This further breaks up the relationship between loads and welds, but is likely overkill for most purposes. It is no longer just a band-saw job, at that point.
Steve
Steve
AdVirMachina
- AdVirMachina
Yeah Steve the band saw is just so quick that it doesn't really add any appreciable time to a build and it looks good and it stronger than a miter. I have taken some good natured grief for "over building" things and I always come back with " if I didn't want it to be strong, I would have used balsa wood and Saran Wrap" If I get a chance, I will run over to the fast lube center the next town over and take a few pics of the hanging catwalks I built many moons ago. Everything is coped and neatly welded...my partner and I were always commended for how slick our work was. I miss those days.Otto Nobedder wrote:Thanks to Jeff, I don't have to draw it. That's an excellent example. One time-consuming variation (which I had in mind when calling the task time-consuming) is to do the reverse side opposite the face side, so the butt is vertical, where on the face side it's horizontal. This further breaks up the relationship between loads and welds, but is likely overkill for most purposes. It is no longer just a band-saw job, at that point.
Steve
I'll have to dig up some pictures of my own. Not related directly to the topic, but to "attention to detail". At an ethanol plant in Iowa, we were building gas trains for the distiller's grain dryers. I did all the fitting, and my partner and I shared the welding. Our meth-head boss was always on us to move quicker... Until the biggest bosshole Fagen ever hired, the pipe foreman for the site (who looked at our little twelve man crew of misfits like something he'd scrape off his shoe) actually complemented us on how professional our work looked.exnailpounder wrote:Yeah Steve the band saw is just so quick that it doesn't really add any appreciable time to a build and it looks good and it stronger than a miter. I have taken some good natured grief for "over building" things and I always come back with " if I didn't want it to be strong, I would have used balsa wood and Saran Wrap" If I get a chance, I will run over to the fast lube center the next town over and take a few pics of the hanging catwalks I built many moons ago. Everything is coped and neatly welded...my partner and I were always commended for how slick our work was. I miss those days.Otto Nobedder wrote:Thanks to Jeff, I don't have to draw it. That's an excellent example. One time-consuming variation (which I had in mind when calling the task time-consuming) is to do the reverse side opposite the face side, so the butt is vertical, where on the face side it's horizontal. This further breaks up the relationship between loads and welds, but is likely overkill for most purposes. It is no longer just a band-saw job, at that point.
Steve
The Meth-head boss would come try to push us now and again, but had lost his magic.
Steve
Clifford_Pierce
- Clifford_Pierce
I have the 41/2in Dewalt and the Milwaukee Fuel with paddle switch and they make a great pair. The Dewalt with a 30-40 grit flap disk has the power to hog material fast and the Milwaukee is handy for the lighter stuff,dressing up etc. Don't expect a 5amh battery to wear you out but with a spare or two it will do a lot of work.
