- big gear head
This is my creation, a small box blade to go behind a gator to level baseball infields. I made it from stuff in our scrap pile. The lift is from an electric dump bed.
- 1BAB2E74-AEAF-46F9-908A-F7E492FF51C3_zpswqccesjr[1].jpg (52.07 KiB) Viewed 2717 times
Tokoroa_Welder
- Tokoroa_Welder
Some more from today...
- IMG_20160214_174823217.jpg (39.93 KiB) Viewed 3047 times
- IMG_20160214_181344452.jpg (37.01 KiB) Viewed 3047 times
- IMG_20160214_174837616.jpg (41.15 KiB) Viewed 3047 times
- Installed....about 50feet total
- IMG_20160214_214737509_HDR.jpg (113.77 KiB) Viewed 3047 times
Hollywood1
- Hollywood1
Beautiful work, Rick,
I do wish I'd taken time to pay more attention to the (top-notch) sanitary welders when I was contracted to Herr & Sacco in PA... They did work for Hershey and M&M Mars, among others, and did absolutely amazing work.
Tried welding razor blades for the first time. All considered pretty happy with it. I should have gotten some mig wire, the 1/16 filler made this harder than it needed to be but the Dynasty arc is so damn sweet.
- subwayrocket
Nice stuff Rick and BigD ! Building a welder cart here. It's 0.125" x 1 & 1/4" square tubing
- WelderCart.jpg (104 KiB) Viewed 2876 times
What model Everlast is that?subwayrocket wrote:Nice stuff Rick and BigD ! Building a welder cart here. It's 0.125" x 1 & 1/4" square tubing
Brian
Miller Thunderbolt 225 AC/DC
Everlast 255EXT with W300 cooler
Hobo Freight 170 MIG Welder
- subwayrocket
250 EXmelsdad wrote:What model Everlast is that?subwayrocket wrote:Nice stuff Rick and BigD ! Building a welder cart here. It's 0.125" x 1 & 1/4" square tubing
A better week this week.
Leo W by Mike Zanconato, on Flickr
Geoff S by Mike Zanconato, on Flickr
Dan R by Mike Zanconato, on Flickr
Zank The man with the machine like welds.
Beautiful.
As nice to look at as the Alaskan scenery posted else where.
Beautiful.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
1" 316L 3000# socket welds...
- IMG_20160220_203617890_HDR.jpg (41.74 KiB) Viewed 2868 times
- IMG_20160220_204552064_HDR.jpg (83.19 KiB) Viewed 2868 times
- IMG_20160220_214537.jpg (77.47 KiB) Viewed 2868 times
- Mock up...don't mind the one steel fitting..just there for fit.
- IMG_20160219_230911943_HDR.jpg (47.38 KiB) Viewed 2894 times
- IMG_20160220_190436570_HDR.jpg (45.79 KiB) Viewed 2894 times
Second attempt at welding razor blades. Using an 040 electrode for the first time, and using 030 mig wire this time. Pretty happy with how it came out. I knew the edge would chew out and started backing off but not quite enough. So much easier to do with the small electrode, makes me want to try pop cans again.
Weld side
Back side
Weld side
- razorblade2.jpg (40.28 KiB) Viewed 2862 times
- razorblade1.jpg (86.73 KiB) Viewed 2862 times
BigD nice job!
Richard- Thanks, yeah I TIG alittle, damn food plant.. Lol Secretly I mig and stick also.
AFR_Autoworks
- AFR_Autoworks
Not what I welded today, but just some final pictures of my last cage. Sorry for the sideways pictures... Always seem to do that when I upload from my phone
- image.jpeg (64.18 KiB) Viewed 2747 times
- image.jpeg (36.32 KiB) Viewed 2747 times
- image.jpeg (56.1 KiB) Viewed 2747 times
- image.jpeg (55.8 KiB) Viewed 2747 times
- image.jpeg (73.95 KiB) Viewed 2747 times
- image.jpeg (63.92 KiB) Viewed 2747 times
Looks good, I always like to plate above the lower tq boxes and run bars down to them as well. The shock tower bar does a lot for the Mustangs flimsy chassis.
Through floor subs???
I have a 25.5 in my 91 GT
AFR_Autoworks
- AFR_Autoworks
I did certainly did consider connecting to the lower TQ boxes. The placement of the main hoop would have made it kind of tricky. This is a drift car so they will not be subject to near the punishment of a drag car. The rear plates/ shock tower re-enforcement was much needed. The car has been converted to coilovers and the added stress on the rear shock towers was starting to separate the layers of unibody around them. It was quite alarming. I ended up rosette welding them through the floor right to the frame rails just to be safe
AFR_Autoworks
- AFR_Autoworks
Also, no through floor connectors. To be honest I don't believe they comply with Formula drift regulations.
Tokoroa_Welder
- Tokoroa_Welder
Just a little dice, 50x50mm squares, tacked up. Will be closed up with tig once I'm a lot better at it.
