- Farmwelding
When you judge political commercials because the welder isn't wearing a jacket or gloves. ( yes it has happened)
maker of things wrote:You nod your head before pulling the trigger on a hot glue gun
Best one so far
I liked the comment about errant patches of skin that no longer grow hair!
I'm working tomorrow, just one other guy and me, and I'm going to get him to take a picture or three of me making the weld I have to do tomorrow, so I can contribute something to this topic.
Just be careful Steve, let's not have one of those, "here hold my beer and watch" moments...Otto Nobedder wrote:I liked the comment about errant patches of skin that no longer grow hair!
That won't happen. This is a fix of one of my f#$kups.
Not a happy camper, but getting time and a half to get it right, so it's all good.
How's that go? One "Oh, Shit" will undo a thousand "attaboy's."
I'm sure you'll get it right, looking forward to the pics.Otto Nobedder wrote:That won't happen. This is a fix of one of my f#$kups.
Richard, you won't believe the stupid crap I did to put myself in this position. That flange repair you saw on IG? I back-welded the inside of the pipe because of being surprised by the second crack. I prepped it with my straight die grinder and a SS wire wheel. Well, screw me, this was a "front exhaust" die grinder, and was puking oil mist and water when I "thought" I was cleaning the weld area. So it failed helium leak test. So I had to back up 5 yards and punt.
I used to keep that die-grinder dry, no oil, and use only nitrogen to power it. So I expected it to be clean. I forgot that I'd planned to retire it from that service (out of balance/bent shaft) and used it anyway.
Poleframer
- Poleframer
Love the ones about burning clothing, the first couple times it's "oh sh*t, I'm on fire", then it's "eh, finish the bead"
When your coffee cups have spatter on them...when you have a box full of perfectly good right hand gloves...when the scrap in your yard is in the tons...when a bottle refill trumps your phone bill...
Tom Osselton
- Tom Osselton
Why do welders only get 10 minute breaks? Any longer and they would have to be re-trained.LtBadd wrote:welders do it with a hot rodTom Osselton wrote:You see the gf naked and say I can fix that!
If you think sliding under this pipe with everything removed from your pockets to make a weld is a "normal day".
- 16602679_900589460082800_7230769518830942187_n.jpg (35.54 KiB) Viewed 2715 times
I see an arc back in there but no welder
I assume you have a torch switch and are not crammed in that space with a pedal between your legs
Jim FLinchbaugh
- Jim FLinchbaugh
HAHAHAHA.FoxZulu wrote:All your clothes have pinhead sized burn holes in them, because it's not worth getting changed just to do that 'quick' weld
all my t-shirts look like I've hit with bird shot
Notapro wrote:I have a problem building something for myself that would be cheaper to buy. Spend a week in spare time to make somthing that would cost $40 to buy. Does that qualify?
but what you build can be given to your grand kids and out last them.
The pedal's on the chair... and that's my LED worklight in the hole.exnailpounder wrote:I see an arc back in there but no welderI assume you have a torch switch and are not crammed in that space with a pedal between your legs
I've got a thumb amptrol, but in this case, the pedal on the chair was easier.
....then you start looking for a lefty welding buddyPoleframer wrote:...when you have a box full of perfectly good right hand gloves..
- Farmwelding
...when a simple cart ends up being 300 pounds because it wasn't strong enough.
- maker of things
You get really irritated every time you hear/read " mig welding is so easy, it's just like using a hot glue gun"
-Jon
Lincoln Viking 3350 K3034-2&3
Lincoln Power Mig 180c
hermit.shed on instagram
Mig welding is so easy, it's just like using a hot glue gun.....
- maker of things
well dang! I just might try it sometime then.
-Jon
