I am able to get some improvement but not able to get a straight and square cut.
Per instructions I start off testing on a 2x2 piece of wood. By twisting the blade guide assemblies I can eventually get pretty close to square and vertical cuts. When I switch to test on a piece of 1" square tubing 14 gauge the vertical cut is off. It seems to cut straight halfway through and then it dives or veers toward the vise. I can adjust the guides to tilt the blade away from the vise side and it helps with the final veer. However, when I switch from 1" to 1.5" /14 gauge square tubing the vertical cut is curved. As it starts the downward cut it follows the tilt of the blade away from the vise and then about halfway through it curves through vertical and eventually goes back towards the vise... a very very shallow "C" shape. If I adjust the blade tilt to be closer to vertical the final veer gets worse. I just can't seem to get a straight square vertical cut.
What I've done so far:
1. New Starret Blade. 0.020" thick, 14-18 TPI
2. New bearing guides
3. top/bottom wheels are in same plane
4. adjust tracking so that back of blade just kisses the back ridge of the wheels
5. moved the two guide assemblies as close as possible to each other.
6. shimmed to get saw assembly to track vertically on pivot. the bushings are not worn so there's no slop.
7. adjusted blade guide to blade clearance (multiple runs ranging from 0.003" clearance to 0.008")
8. varied blade guide assembly tilt so the blade can be adjusted from vertical to tilted in either direction (undercut and ??cut)
9. varied blade tension
10. varied feed rate by adjusting preload on spring.
Results/Problem
I can't get a straight and square/vertical cut in square tubing. If I adjust the blade to be near vertical, the blade will start to veer towards the vice (undercut) in the lower half of the cut.
As a last resort I cut a bit of 3/16" x 1" bar stock and the C curve is slightly less. Only one test due to time limitations.
Considering the fact that the cut on the thicker material (bar stock) seemed better, I'm considering getting a plain 18 tpi or even a 24 tpi blade to put more teeth in the material.
Does anyone have an idea what to try next?
Apologies for the loooong post and the painfully silly details but I'm getting a bit frustrated. I switched from a portaband to this saw hoping for better easier results and I'm spending days farting around.
I'm going to fix a cocktail and pout.
steve
