ryanjames170
    Sun Sep 25, 2016 12:46 pm
    Wisconsin
any one here use 6013 for anything? if so what is it good for?
Welder/Fitter
RM Fab & Products
Lincoln Invertec V300 pro
Miller 54D Wire Feeder
Miller 2E DC Welder Generator
Everlast Power IMIG 200
Everlast Power ARC 200ST
6013 gets a bad rap. You'll hear it called "farmer rod", and there's a fair reason for that. It will weld fine on the old beat-up AC machines you'll find on very many farms, and it's ability to weld through rust, mill scale, and crud makes it useful for the farmer who has to get his equipment fixed "now".
That said, it's designed for low depth of penetration with a broader puddle, so it's suitable for thinner sections. It works well on thicker welds if done in multiple passes.
More years ago than I want to think about, I built boat docks, and we used 6013 on ancient machines for production work, because in flat position you can really crank it up and put a lot of metal down fast.
I used it recently to build two carts for our vacuum pumps.
2015-07-10 06.07.49.jpg (92.16 KiB) Viewed 1743 times
2015-07-10 06.08.20.jpg (71.85 KiB) Viewed 1743 times
    Wed Jan 22, 2014 12:00 am
    Connecticut
it is apparently used for a fair amount of pipe welding outside the USA.
Multimatic 255
    Wed Jan 28, 2015 7:27 pm
    Portugal
I use it a lot but that is probably because I'm a farmer :lol:
Welds good on many things.
That and 7018 and nowadays I have a mig as well.
Artie F. Emm
    Thu Jul 24, 2014 7:53 am
Otto Nobedder wrote: it's designed for low depth of penetration with a broader puddle, so it's suitable for thinner sections.
For instance, car exhaust tubing.
Dave
aka "RTFM"
    Sun Oct 27, 2013 10:57 pm
ryanjames170 wrote:any one here use 6013 for anything? if so what is it good for?
I use it for general fab - it's good for mild steel.
I like 7014 as well - I also use 7018.
