Hello all,
I am a welder at a tool shop. We recently took on a new job that involves welding a stainless steel cap onto a 4"steel pipe. The welder that used to do this job is retiring and attempted to show us at the tool shop. There is an 1/8" gap weld with the 3/32" ENiCrFe-3 rod. He was showing me using an 1/8" rod because that size was all that we had on hand. He had the welder set at 85 amps DCEN. The whole time he was having issues running a bead and having the slag form worm holes. The welds he did ended up having to grinded out and redone many times on the same Pipe. I was thinking that maybe the amperage was to cold for the slag to rise, but I am fairly new to welding and did not want to try and question the old timers methods. We recently received the 3/32" rod and I will have to weld together three of these pipes. Does anyone have any experience with this rod and type of weld? I would really appreciate any advise that will help me get this weld done right.
- image.jpeg (49.97 KiB) Viewed 363 times
- image.jpeg (47.91 KiB) Viewed 363 times
Definitely use it if that's what the called for. Most SS stick is hard to get a handle on at first. Some versions of the same rod are meant for flat work only. If you try to run down hill it will trap slag like you described.
