I want to think everyone for their help.
I think I actually succeeded in repairing the base. Notice I didn't say "welding" it. The mess I made is so sloppy, I'm not sure it even qualifies to be called a weld.
I used 308L wire. I had read that non-magnetic stainless was the thing to use. I heated the piece to somewhere above 100 degrees, according to the strange instructions I read elsewhere. Then I did what I ALWAYS DO 100% OF THE TIME. I started welding without turning the gas on.
I ground off as much of the spongy crap as I could and started over, with two small welds on the bottom side. I had the wire feed turned up, according to something I had read. What a mistake. I was only welding a few seconds, but I ended up with big globs again. Back to the grinder.
I beat the globs with a ball peen hammer and then ground off the excess. I never heard the "tinking" sounds you're supposed to hear when cast iron welds break. That's the main reason I'm posting this. I would like to know what went RIGHT. I can't understand why the welds didn't pop. Maybe because they're shallow? I only v'd out maybe 3/32", because I was afraid if I didn't leave some meat it would be hard to hold the pieces together while I welded. As it was, I had to use a Bessey clamp.
I ground off the new globs and did some more welding. Still too much wire, but no popping noises.
I removed as much excess metal as possible and tested the repair by yanking on it and beating it with the handle of the hammer. It's probably the worst weld in the universe, but it's aligned perfectly and will probably work well enough for the purpose of holding a motor down.
I may be able to clean it up some more if I can find the right rotary tool.
This went incredibly well, even though it looks like there is no possible mistake I failed to make.
- Chips O'Toole
- 12-10-16 mitsubishi motor mount MIG welded 308L wire small.jpg (66.87 KiB) Viewed 1048 times
- Chips O'Toole
You joke, but I was planning to do that today.Oscar wrote:I would think that by now, you knowing your yourself, would have put a label on your MIG gun with a note to turn the gas on before squeezing the trigger.
- Chips O'Toole
I don't want to get in trouble with Zod.
- Chips O'Toole
I wasn't kidding!
- 12-12-16 lincoln welder with gas sign small.jpg (42.94 KiB) Viewed 526 times
- MosquitoMoto
Well, I'm glad that worked out well for you.
I only forget the gas...when I'm welding something absolutely critical. If I'm practising or just zapping something of no real consequence, I turn the gas on.
But any time a mate shows up and says something like "I have this hand-formed 1mm thick aluminium aircraft blister cowling that's 75 years old and utterly irreplaceable, do you think you could repair it?" ... THAT is when I will forget to turn the gas on.
Kym
Kym
- Chips O'Toole
That makes complete sense to me.
I prefer not to discuss the time I left the gas ON.
That is always a sad day. Out to the shop to weld something up quick. Go to turn on the gas and your first thought is who cranked this valve down because I can't open it? Then you realize it's already on! SOB I'm an idiot!
- ldbtx
Sure glad I'm not the only one that's done thatPoland308 wrote:That is always a sad day. Out to the shop to weld something up quick. Go to turn on the gas and your first thought is who cranked this valve down because I can't open it? Then you realize it's already on! SOB I'm an idiot!
Miller Bobcat 225
Tweco Fabricator 211i
AHP AlphaTIG 200x
Lincoln SP-135+
Hypertherm Powermax 30 Air
ProStar O/A torch
AHP AlphaTIG 200x
Lincoln SP-135+
ProStar O/A torch
