Okay now that we got test results let's check couple of other things.
1. Your tungsten stick out, how much do you have. With a #5 standard you can not have much stickout I use CK worldwide recommendation that stick out be no more than 3 times diameter of tungsten. Also #5 is not gonna give you real good gas coverage as you move forward. The metal behind the weld pool will be exposed to the oxygen while still hot. Cup just not big enough to cover that area. To me this cup is waste of time on stainless to begin with.
2. What did your tungsten look like after test, was it blue or black instead of looking like it's normal color. If so increase post flow so gas keeps tungsten from oxidizing while hot.
3. Make sure to keep torch over area after you stop arc until post flow stops
4. Arc length keep tight arc length. Here is what I mean by tight length, arc length is same as tungsten
5. Correct any issues above and retest.
Took some sample pics to give you stick out reference and how weld pool looks with couple of different cups. Same tungsten and flow rates for all just different collets and cups. These are just puddling metal. Used same piece of metal wire brushed between cup changes. Can see old puddle from previous cup in couple of pics.
This is a number 5 cup 3/32 2% lanthanated tungsten 1/8 304 stainless flow is 15. Notice some blue coloring in puddle around core.
Number 8 cup. Notice it gets used more than standard cup. Personally never use standard cups, figure I get better coverage with a lens why bother with regular collet bodies. Notice puddle is shiny, blue color is outside of weld puddle. I should have used a new lens, This lens is headed out to junk pile, has crap built up on screen.
1 1/8 inch cup. This cup I get better results if I turn up flow for this demonstration it is same setting though.
dirtmidget33
- dirtmidget33
Thanks for the info. I just piced up a #8 cup to try. I will order a gas lens kit soon as my budget allows.
For now I will go through what you posted and will get back to you when I`m done.
My machine is all manual, so I am the pre flow and post flow control.
My Tungsten stays clean, I guess I either have the flow correct for that or am holding longer. I ussually count to five for pre and post. Thanks.
dirtmidget33
- dirtmidget33
Your welcome hope you get it figured out.
- GreinTime
You can start welding before you count to one for your preflow my friend. You're just wasting argon in 95% of the casesDanylo66 wrote:Thanks for the info. I just piced up a #8 cup to try. I will order a gas lens kit soon as my budget allows.
- 1/16 Stainless square tube.
- IMG_20170204_131141523.jpg (33.23 KiB) Viewed 7591 times
- Pie cut 3" Stainless practice.
- IMG_20170401_231318339.jpg (40.28 KiB) Viewed 7591 times
It took me a long time to find this, as I was trying out all the different ideas that everyone posted.
It was frustrating but in the end with all your help I believe ive become a better welder.
Great learning experience.
From now on i will do a leak test more often. I need to pick up some more leak test solution, but its cheaper then running out of Argon to quickly. The Argon supplier changed out the bottle at no charge. Later when I found the leak at the regulator I offered to pay for the bottle, but he would not take the money. I offered to pay at least half and we settled at that, so that was good.
THANKS Danylo Iwanusiw
- Last fitting afterthe regulator leaked.
- IMG_20170403_193241540.jpg (32.59 KiB) Viewed 7591 times
- Farmwelding
Wow... Thats a nice welding supply store
Yes there great. Not sure if i can post there name, don`t know the rules on that, They have been so patient with me since I started. I walked in the first time and stated I know nothing about Tig welding and they walked me through of what I needed. Even Gave me discounts as opposed to the other suppliers. Not bad mouthing the others, they are only able to do so much.
Not sure I follow what you're saying, you're using the solution to check around gas connections for leaks, right? I use a small brush, like an acid brush to apply.Danylo66 wrote:I was always under the impression that soapy water affects the gas.
If it does not thats great alot cheaper.
Thanks
- acid brush.jpg (31.91 KiB) Viewed 1452 times
If your worried about corrosion then go to a heating and cooling supplier. Look for something like this
http://www.supplyhouse.com/Nu-Calgon-41 ... ector-6-oz
It will already have an applicator in the cap. And that is enough to last you years.
I get what your saying, but I heard it was not good to use dish sopa. But if you have used it and the weld was not affected then I will give it a try.LtBadd wrote:Not sure I follow what you're saying, you're using the solution to check around gas connections for leaks, right? I use a small brush, like an acid brush to apply.Danylo66 wrote:I was always under the impression that soapy water affects the gas.
Thanks
Ill look into it ThanksPoland308 wrote:If your worried about corrosion then go to a heating and cooling supplier. Look for something like this
The leak detector solution we use at work is the name-brand Swagelok Snoop, because that's what a major client specifies, and it works great. For a dirt-cheap home-made alternative, use one gallon distilled water, one tablespoon plain green dish detergent (like Polmolive), and one teaspoon Glycerin (available at better pharmacies).
If you use a quart of distilled water, this is awesome bubble solution for your kids.
Yea, we have the Swagelok at work also...Swagelok = $$$ but also quality, some years back I got to fly out of Clearwater on Swagelok's jet with a group to tour their facilities, great experience.Otto Nobedder wrote:The leak detector solution we use at work is the name-brand Swagelok Snoop, because that's what a major client specifies, and it works great. For a dirt-cheap home-made alternative, use one gallon distilled water, one tablespoon plain green dish detergent (like Polmolive), and one teaspoon Glycerin (available at better pharmacies).
Thanks. Any idea what the Glycerin does? I`ll Google just to know .Otto Nobedder wrote:The leak detector solution we use at work is the name-brand Swagelok Snoop, because that's what a major client specifies, and it works great. For a dirt-cheap home-made alternative, use one gallon distilled water, one tablespoon plain green dish detergent (like Polmolive), and one teaspoon Glycerin (available at better pharmacies).
The glycerin provides a super-thin film of oil over the bubbles to slow drying, so they are apparent before they burst. This same property makes it a great addition to a child's bubble mix.
Swagelok has a great sense of humor as a company. To order a bulk pack of their trolls of Teflon tape, for example, it shows up on the order form as "Strip, T's". Their anaerobic Teflon pipe dope is "SWAK".
Love it.
Love it.
Cool Thank you.Otto Nobedder wrote:The glycerin provides a super-thin film of oil over the bubbles to slow drying, so they are apparent before they burst. This same property makes it a great addition to a child's bubble mix.
