I have a new Everlast EXT 255. I actually got it a year ago, just now getting it set up. It came with a WP-20 torch & it seems to have a problem or I am just doing something wrong. When I turn on the water pump, the water comes out the ports where the argon is supposed to come out. Does anyone know what might be the problem???
sedanman
- sedanman
Someone connected the hoses wrong. Could have been them, could have been you. I don't envy the clean up job you have ahead of you. All traces of coolant need to be flushed out of the argon line and it needs to be bone dry.
At least there is no "argon return line" that would have taken the mis-routed coolant back to the welder!
Just take it all apart, fill up your sink with warm water and dawn, and give the whole torch a good cleansing. Then connect the hoses correctly. The power cable can only go one place, but it's the other two, the coolant source hose and the argon hose, that can and did get mixed up.
