I followed Jamie's build and used what i had on hand. These really work well. I was able to bring a gallon of water to a full boil. A lottle clean up and paint......done.
NIce work. I am laughing because someone else posted their stove in "what I welded today like 5 minutes before you did". Good job though...they work great but forget about trying to keep paint on it.
- Farmwelding
Yep forget the paint-when you have that hot of a fire-ain't no way no paint is staying on there for long.
rahtreelimbs
- rahtreelimbs
exnailpounder wrote: NIce work. I am laughing because someone else posted their stove in "what I welded today like 5 minutes before you did". Good job though...they work great but forget about trying to keep paint on it.
That would be me, LOL, I haven't decided upon the feeder tube being maybe 20 degrees up or flat. Looks good whatever works, I know I will use mine at camp. Mine breaks down to fit in a bucket.
- Rocket stove in bucket.JPG (53.71 KiB) Viewed 2351 times
- Rocket stove project top view.JPG (68.45 KiB) Viewed 2352 times
Couple years ago I built a box stove for the big shop. The box is 2ftx3ft with firebrick and a 3/4 length shelf 4in down from the top. On top is a 12in sq. X2ft6in. heat exchanger with a pipe thermometer in the end. There are 3 adjustable air inlets with one being an auxillery perforated tube at the top of the firebox. No problem according to the thermometer getting north of 1400 degrees in the exchanger with decent wood! As for paint it's just Beauty-Tone high heat rated for 1200 degrees so there must be some redundancy. The exterior flue temperature will be cooler due to convection air flow around the outside I have no idea the temps a rocket stove hits but that may give you an idea on the paint . Mine still looks good as new.
Nice work! A big fan of the rocket stove technology, so much I am currently working on a microprocessor to control the heat dissipation and automatic wood feed of one of these things. Just about finished with programming, working terrific. Good looking welds.
