408cheytac wrote:The problem is where the door hits the case it's completely flush and if I place it there it will stick up a bit.
You know there are a "flared" version of them? They are easy to recess.
You just need to drill and counter-sink a hole and just press down a screw. If you can't use a press or the bench vise just put a nut behind and tighten. 16 gauge SS might need some heat though.
Tools for the riv-nut can easily be made too. The threads in the long nut has been drilled out. Just hold the stem steady and tighten the small nut and its done deal.
The attachment IMG_20170317_33627.jpg is no longer available
I didn't think of that. I was a thinking of maybe a rivet looking piece like the ones where the bottom of the rivet head is a square. Right now I have it set up with just standard case screws. The one drawback of the case is that it's a bitch to take off.
