Lincoln Squarewave 175
Lincoln Ranger 250 GXT
Lincoln SP 125
Lincoln Idealarc250
Miller XMT304
Miller Suitcase X-Treme 12VS
Millermatic 200
Hypertherm 85
Torchmate 4x4
Cincinnati Mill
Atlas 12 inch lathe
Atlas small horizontal mill
Shop built guillotine bender
" " Plate roller
20 ton press
And a friendly little mouse who keeps me company when I am here late at night
Parker Metalworking TIG/Stick
Miller plasma
Victor O/A
Harris O/A
Milwaukee portaband
Bosch and Dewalt right angle grinders (2-3 of 'em, keep a wire cup on one, cutting, flap disk, etc. on the two Dewalts)
Whatever brand of tools I end up finding deals when there is a need, and no glaring faults warning me away from.
Had a Lincoln SP135+ MIG until an acquaintance had great need for MIG, and I hadn't been using MIG in a while.
Miller plasma
Victor O/A
Harris O/A
Milwaukee portaband
-Josh
Greasy fingered tinkerer.
Tom Osselton
- Tom Osselton
Atlas small horizontal mill!DrDogwood wrote:Lincoln Squarewave 175
Lincoln SP 125
Lincoln Idealarc250
Miller XMT304
Millermatic 200
Hypertherm 85
Torchmate 4x4
Cincinnati Mill
Atlas 12 inch lathe
" " Plate roller
20 ton press
Now your making me drool! I've been loking for one for a while, I have the lathe and shaper.
Tom Osselton wrote:Atlas small horizontal mill!DrDogwood wrote:Lincoln Squarewave 175
Lincoln SP 125
Lincoln Idealarc250
Miller XMT304
Millermatic 200
Hypertherm 85
Torchmate 4x4
Cincinnati Mill
Atlas 12 inch lathe
" " Plate roller
20 ton press
The little mill sets mostly idle since got the Cincinnati But it still gets used for the odd little job
I forgot the Makita carbide cold saw and horizontal band saw
I was building a lot of small Backhoe buckets for A while so I built the plate roller it will bend 37" of 3/16 plate around a 12" die
My Grandfather Used to say "Grinding a weld to make it pretty doesn't make you a Welder. It makes you a Grinder!"
My shop is mostly a woodworking shop, with one part near the garage port for metalworking, usually I have it so I can roll out my metalworking stuff on the concrete infront. I got a single welder, a 23 year old Kemppi Minarc TIG 300A, DC only stick and tig combo that I retrofitted with a CK torch and homemade pedal. Before that I had a cheaper older kemppi stick welder.
I buy and use almost exclusively old quality machines, usually requiring some renovation. My oldest machine is my woodworking bandsaw which is anywhere from 60-70 years old. Future purchases would be a better drill press, preferrably something like a swedish Arboga or Strands, an older cast iron jointer/planer combo is also in the cards. But I got a small aluminum one that I am making do with.
I would someday like to expand into the smaller room in my garage, once I have built a whole new storage to put the stuff I currently store there into. Then I'd like to put a metal working lathe there perhaps. Maybe a swedish blomqvist (a metric southbend clone)
This is the welder and my welding table, it's onwheels so I can roll it outside for welding work:
I am into homemade tools as well, this simple belt grinder has been very useful, it was primary intended to sharpen chisels, but it gets used for all kinds of metal shaping, eventually I will build a bigger metal belt grinder.
I recently made a sheet metal brake, also the vise is homemade:
(quoted above)
I forgot about mills & lathes!
Craftsman (Clausing) lathe, pops up at Sears Service Center as: "Yeah, we sold this once-upon-a-time" (part # on a blank sheet)
18" Russnok vertical (and horizontal!) mill from WWII US Navy. The base, (heavy cast iron), made by Singer Sewing Machine Co.
Unimat mini lathe & mill attach. (bought from Sears! catalog in early '70's)
Craftsman (Sherline) mini lathe.
Tom Osselton
- Tom Osselton
- Clausing 1.jpg (40.84 KiB) Viewed 1309 times
- Clausing 2.jpg (35.87 KiB) Viewed 1309 times
Nothing wrong with Clausingcornmuse wrote:(quoted above)
motox wrote:
HTP 221
miller 250 syncrowave
miller 140mig
electrode wrote:
Ditto except my mig is a Hobart Handler 210 (220V only) and Oxy/Acet rig, and Hypertherm plasma cutter. And plenty of machine shop machines.
hypertherm plasma too, should have bought the 210 instead of 140. here to plenty of machine shop and fab tools.
HTP 221
miller 140mig
WildWestWelder
- WildWestWelder
Miller 252 with spool gun
A Miller Dynasty 280 in the near future
72" x 40" x 1-1/4" welding table blanchard ground flat
Butt loads of clamps
CNC mill
CNC lathe
CAD and CAM software
Manual mill and lathe
4' x 6' x 10" surface plate and lots of precision measuring tools
Lots of good quality hand tools
Martin 00016 guitar
JBL sound system
2400 SF to put them in
I use this shop to make a living in but it is also my man cave. I'm there 7 days a week.
CNC mill
CNC lathe
Martin 00016 guitar
JBL sound system
Welders
Lincoln 100 fluxcore mig, My first Mig experience.
Millermatic 140, I like this machine alot
L-Tec 250 heliarc with bernaard cooler and 18 torch, Like it alot! Stickwelds like a dream too!
WW 2 era Gisholt turret lathe
WW 2 era Milwaukee Horizontal compound table mill, I have made gears on this machine
Acet and ox
Harris E-16 I use for brazing and small stuff
A bigger smith for heavier cutting and rosebud work.
14" Chop Saw
Chinese Band saw
3 Angle grinders
Die Grinders
F clamps
Visegrips
I like making things from Steel, Stainless And Aluminum. Woodworking is NOT for me.
Acet and ox
14" Chop Saw
Chinese Band saw
3 Angle grinders
Die Grinders
F clamps
Visegrips
WildWestWelder
- WildWestWelder
I am the same as you. I love wood but me and wood just don't get along. Metal is where it's at!Notapro wrote:
kiwi2wheels
- kiwi2wheels
+ 1.WildWestWelder wrote:I am the same as you. I love wood but me and wood just don't get along. Metal is where it's at!Notapro wrote:
The # 1 trouble with wood is you cant weld it back when you screw up !
Hmmm....welders, huh?
Lincoln Ranger 8 (only 98 hours) and an AC/DC buzz box
3x Miller Dialarc 250s, two white face, one black face
An old Astro MIG 120 volt wire feed welder
Lance
Lance
LanceR
Miller Multimatic 255
Hypertherm Powermax45 XP
Heck Bevel Mill 4000
Ace fume extractor
Welding/cutting/brazing torches
Ace fume extractor
Miller Passport, Dynasty 300, Spectrum 2050, Esab SVI300, MIG 4D wire feeder, Miller Spool Gun 30A, Scotchman Cold saw, band Saw, Belt-Disk sander, Drill Press, grinders, 1966 Kellogg 2 stage air compressor,CK WF-3 cold wire, and a 50 cu. ft. commercial refrig. full of beer! LOl No wonder I can't get anything done!
Pete
Pete
Pete
- Farmwelding
You keep up the beer and I will take the shop and it will all work out. I'll help get your stuff donepgk wrote:Miller Passport, Dynasty 300, Spectrum 2050, Esab SVI300, MIG 4D wire feeder, Miller Spool Gun 30A, Scotchman Cold saw, band Saw, Belt-Disk sander, Drill Press, grinders, 1966 Kellogg 2 stage air compressor,CK WF-3 cold wire, and a 50 cu. ft. commercial refrig. full of beer! LOl No wonder I can't get anything done!
Pete
- MosquitoMoto
Small shed, modest collection of stuff.
Metalmaster Elite 215 ACDC Tig/stick/plasma. Tokentools 142 Miniarc stick welder.
McPherson 14 inch band saw.
Woodfast 10 inch band saw.
Makita high speed metal cutoff saw.
Makita mitre saw set up for aluminium.
Old manky drill press.
Half a dozen angle grinders.
Half a dozen cordless drills.
Half a dozen motorcycles.
Desperately wanting a lathe and a mill.
K
K
