I see in the original pictures a complete lack of root penetration. I also saw a comment that you can't get root penetration without the weld dropping out.
That's nonsense. I see in the broken weld picture you didn't even nick the edge of the tube. You're building a weld bridge, not making a weld joint. The root must break the edge of that tube if you want strength in the joint.
Gavin Melville
- Gavin Melville
I realise I'm not getting root penetration, but the comment about the weld dropping out wasn't mine. A work in progress.
You've gotten all the right information, but its scattered all over the place within these posts...
- 200 Amps is low for the wall thickness, especially on an ally joint. Bump it up.
- Probably, your tungsten is too far away from the joint when you hold the cup into the notch. Lay your filler wire along the joint, place your cup, then look how far away it is. Ideally, it will be just farther than the filler thickness.
- Preheat both pieces to establish a puddle faster.
You can experiment with these settings by tacking. If you can get the weld to be more concave than convex, you're getting it deeper. 1"x3/16" square tubing is a fright to weld because the heat accumulates so quickly that you can not loiter once you get your puddle, but you have to get the puddle right first. Start away from the corner, then back up to it, or weld from the middle of the face around the corner to the next. Starting and stopping in the middle and tie-ins in the middle. Easier to avoid blowing out your tubing if you are welding fully around the tube.
Gavin Melville
- Gavin Melville
Thanks,
All that makes sense. If I join the faces first and extend the weld a little around the corner I get better results on the fillets. I'll try starting in the middle on this. I've only got 230 Amps, so that will have to do.
In the past I've ended up with concave welds once I got things hot enough, needing a second pass.
I was hoping for small neat welds
You might try your smash test on those "concave" welds too. Don't discount them due to their appearance. As long as you are getting sufficient fill, the height of the weld doesn't matter as muchGavin Melville wrote: In the past I've ended up with concave welds once I got things hot enough, needing a second pass.
That comment about full pen was me and the truth is you can't get complete pen on a filet. You can cut and etch any filet and see what penetration you get and they are never all the way through, now on a gapped butt weld you can get full pen. If you did get complete pen, that means you would be all the way through 3/16" of wall, into the inside of the tube and then you would have an overheated mess. I suggested the OP was dipping in the keyhole and not letting the puddles join. You have to dip in the keyhole on a butt joint cause thats all you have to dip in. I guess I had typing palsey when I wrote that...alcohol was involved.Otto Nobedder wrote:I see in the original pictures a complete lack of root penetration. I also saw a comment that you can't get root penetration without the weld dropping out.
You can still get "small neat welds" if you want. Just bevel the joint prior to welding, I have a Dynasty 200 machine, I build a fair amount of stuff in commercial use and some things are thicker than what 200 A can handle so you BEVEL it to make the thickness less right in the joint, just pick up a grinder and grind it in the corner and bring it in 1/8" or so on both sides or 3/16" on one side and weld the piss out of it and make sure you get that joint and you can have some really pretty welds by the end of it that won't have to be super big and ugly.Gavin Melville wrote:Thanks,
Don't even bother with the second pass. Not necessary if you bevel and it double pass looks like shit IMO.... Unless its pipe, then It's good.
What I said didn't quite lead to what I meant. I meant penetrating the full depth of the fillet, fusing the corner of the leg , as opposed to bridging over it and leaving the corner intact. I wasn't trying to imply full penetration.exnailpounder wrote:That comment about full pen was me and the truth is you can't get complete pen on a filet. You can cut and etch any filet and see what penetration you get and they are never all the way through, now on a gapped butt weld you can get full pen. If you did get complete pen, that means you would be all the way through 3/16" of wall, into the inside of the tube and then you would have an overheated mess. I suggested the OP was dipping in the keyhole and not letting the puddles join. You have to dip in the keyhole on a butt joint cause thats all you have to dip in. I guess I had typing palsey when I wrote that...alcohol was involved.Otto Nobedder wrote:I see in the original pictures a complete lack of root penetration. I also saw a comment that you can't get root penetration without the weld dropping out.
Sloppy language on my part.
Full penetration can be achieved on a fillet through prep work, by beveling the leg to a small land or a knife edge, though it's not always practical or useful. When both sides of a leg are welded, or in this case the tube is welded 100%, full throat depth is all that's required so your weld is as strong as it's size implies.
Gavin Melville
- Gavin Melville
Could one of make a simple drawing of how a beveled fillet joint might look - I must be thicker than usual this morning.
I'll give it a shot. I haven't used MS Paint in a long time. Failing that, maybe a bar-napkin sketch to scan or photograph.
Edit... sketch it is. Can't draw a straight line with my trackball.
Gavin Melville
- Gavin Melville
That took a minute... I forgot I needed to reinstall the drivers for my printer/scanner.
Here's a crude sketch, showing a tee joint, and a pipe-to-plate. I've drawn it with a land, rather than a knife-edge, since you're working with aluminum. A knife-edge would just blow out. The bevel will need to be at least 45* up to about 60, depending on the thickness of the material, so you can get in to the corner.
Working with Stainless would require purging the back side of the tee or the inside of the pipe/tube for the first pass, since the material is thinned out enough for full penetration.
- Scan.jpg (23.93 KiB) Viewed 1564 times
Gavin Melville
- Gavin Melville
Ok, got that. I'll be at work in an hour and can try it then. I didn't think of that, on the surface it appears to make the problem worse.
It's not really needed for what you're doing. It's seldom needed unless a procedure calls for it. The trick is to get the tungsten very close when you start your arc, and get both sides of the joint to puddle all the way to the corner. You may have to manipulate the torch, as the arc will favor one side. Once you're molten to the corner on both pieces, add your first dab of rod, drawing the torch back a bit as the puddle will swell rather quickly. Advance to the front edge of the puddle, and don't add rod until you see the previous addition start to flow into the corner. Lather, rinse, repeat.
Gavin Melville
- Gavin Melville
Thanks Otto,
Fillet joints have always been my nightmare. All other joints, and "open" fillet welds are fine. Once I get to 90 deg it just doesn't work so well. This thread has given me some good ideas.
Out of admiration...I won't make you apologizeOtto Nobedder wrote:What I said didn't quite lead to what I meant. I meant penetrating the full depth of the fillet, fusing the corner of the leg , as opposed to bridging over it and leaving the corner intact. I wasn't trying to imply full penetration.exnailpounder wrote:That comment about full pen was me and the truth is you can't get complete pen on a filet. You can cut and etch any filet and see what penetration you get and they are never all the way through, now on a gapped butt weld you can get full pen. If you did get complete pen, that means you would be all the way through 3/16" of wall, into the inside of the tube and then you would have an overheated mess. I suggested the OP was dipping in the keyhole and not letting the puddles join. You have to dip in the keyhole on a butt joint cause thats all you have to dip in. I guess I had typing palsey when I wrote that...alcohol was involved.Otto Nobedder wrote:I see in the original pictures a complete lack of root penetration. I also saw a comment that you can't get root penetration without the weld dropping out.
Ding dang...you can get a full pen weld on that bad boy.Otto Nobedder wrote:That took a minute... I forgot I needed to reinstall the drivers for my printer/scanner.
Gavin Melville
- Gavin Melville
Some progress. Back to basics - here is a butt joint welded the same as above, .1 in thick 6061, 100 amps (actually 70 was enough), 120 Hz. I assume that is OK, certainly strong enough.
The fillet joints are still eluding me, will post back when I've got one etched.
It might be the 6261 aluminium that is making things hard - fillet joints with the SHS shown here are better. It's thinner, and also 6061.
I'd like to see a fillet joint snapped or etched - anybody got one ?
- IMG_1433.JPG (15.54 KiB) Viewed 1478 times
I will try to do a fillet cut and etch tomorrow, as time allows. I have a bit of material set aside, as I wanted to do one today, but I'm pressed pretty tight until after Friday.
The material will be 1/4" 5053, and I will likely weld it with 4043 or 4943, for a good contrast in the etch.
- 20170426_074100.jpg (51.18 KiB) Viewed 1465 times
- 20170426_080658.jpg (52.72 KiB) Viewed 1465 times
Unknown base metal .125, 3/32" 4043 filler, 140 amps, pedal, 18cfh, 3/32" 2% lanthanated tungsten (micro balled)
Nice, Jeff, and a great analysis on the base penetration. I think this could be limited with torch angle adjustments, but it may be finer control than a blind shaky guy like me can manage. I won't get to do a cut/etch before Saturday, as there's a priority job right now that's meant to be done Friday, and I always get the priority jobs...
What did you etch with?
I used Naval Jelly and when I thought that didn't do a good job I used oxalic acid( Barkeepers Friend) Not ideal but better than nothing and the details show.Otto Nobedder wrote:Nice, Jeff, and a great analysis on the base penetration. I think this could be limited with torch angle adjustments, but it may be finer control than a blind shaky guy like me can manage. I won't get to do a cut/etch before Saturday, as there's a priority job right now that's meant to be done Friday, and I always get the priority jobs...
First thing I'll try is Alubabrite. It quickly etches clean aluminum, but I'm not sure it will contrast the weld nugget. We'll see. I know it works a treat on stainless steel that's had the CrO2 recently buffed off.exnailpounder wrote:I used Naval Jelly and when I thought that didn't do a good job I used oxalic acid( Barkeepers Friend) Not ideal but better than nothing and the details show.Otto Nobedder wrote:Nice, Jeff, and a great analysis on the base penetration. I think this could be limited with torch angle adjustments, but it may be finer control than a blind shaky guy like me can manage. I won't get to do a cut/etch before Saturday, as there's a priority job right now that's meant to be done Friday, and I always get the priority jobs...
Also, I'll be welding known material. 5052 base with 4943 filler.
Will report results, of course.
Gavin Melville
- Gavin Melville
