exnailpounder wrote:
Otto Nobedder wrote:I would use 316 throughout, and an over-alloyed (fully austinitic) filler. Eliminating ferrite in the weld will go a long way to stopping crevice corrosion. Here's a quote from a discussion I had recently with a welding engineer, "Examples of filler metals which solidify austenitically are AXT, 310, 310L, 383, 385, and a urea grade 25.22.2.LMn."
Note, the reason most common fillers leave residual ferrite is to prevent hot-cracking of the weld, which means you have to control both heat input (Pre-heat is advised) and cooling rate, perhaps even peening the weld during it's initial cool to interpass temperature.
Steve
So..in your opinion..would 316 work throughout? I think it would. I have been in refineries and seen all types of SS take some serious abuse and hang in there. Refineries are not the place to say...maybe this'll work :lol:
Yes, when welded with 310/310L or the higher alloys mentioned above. Austinitic stainless is succeptible to stress-cracking in a chloride environment (salt water) when there are grain boundries between the austinitic phase and the ferrite crystals in a 308 or 316 filler weld. A fully austenitic weld "should" prevent or reduce that.
Steve
    Thu Dec 25, 2014 9:25 am
    near Chicago
lostsoul wrote:The rudder is a 1974 on a 1974 boat. I have owned the boat for 20 years.
As far as I know, the rudder was not rebuilt before I owned it, but I cant be sure. There are many other boats of the same model and year and some owners have rebuilt theirs. Many just scrape out the old foam and dont really expose the welds. But others have done something similar.
But this method of rudder building is common. It tends to last a long time. I could buy a replacement rudder which would be built in the same manner. Big bucks though. There is a place called Foss Foam that makes new rudders. I think they use all SS and not a more corrosion resistant alloy. Thing is to keep the sea water out is key. But it will get in at some point, it is just a matter of time.
I have the 316 post and ribs pretty much set to be welded. I stopped by a shop and they said "no problem, be less then $100". But they dont seem to understand that this welding needs to be well done to be corrosion resistant. For me, I dont know exactly what they should do. Maybe I should trust them? I would like to learn more about this so I get it dont the best it can be. After all I dont want to have my rudder fail. It is not like a flat tire.
I know that the old ss post was welded to plain steel for 40 years and did not fail. (almost). I just like to do things the right or best way. I am not a good enough kind of guy.
Thanks for the comments guys!!
frank
Frank..I understand wanting to do things the right way and that is truly commendable. I think your set up in 316, properly welded, will outlive us all and be safe. I know it would suck to snap a rudder at sea but if you find a competent welder you should have no worries. I heard Lt Badd is going to contact you. He'll make sure it's done right.
    near Chicago
Steve
Steve
I have read about a few SS filler rods that are supposed to prevent and/or lessen carbide precipitation in the HAZ...I can't recall what they were but from what I have been able to ascertain, 316 should be the ticket. Gosh...what do you do for a job so simple but so complex?
My job's not as complicated as this.
My curiosity leads me to information like this. Remember the discussion about why stainless becomes magnetic in certain situations? This information comes from my research into that question.
I might never use it, but now I know it.
Steve
lostsoul
    Tue May 09, 2017 9:25 pm
Thanks guys.
Been a while since I have been in discussions of ferrite, austenite, body centered cubic, face centered cubic, etc..
My conclusion is that I will just make sure the welder uses a 316 rod when welding. I know there could be more done to treat the weld, but not sure it is necessary. It would be nice to know though. I doubt this much thought went into the original fabrication.
I am posting a couple of pictures to go with an email exchange with Richard..
lostsoul
only one pic loaded, here is another
    Tue Dec 13, 2016 9:24 pm
    Clearwater Florida
Make sure it gets repassivated, Im tellin' ya, it'll make a big difference.
lostsoul
Olivero wrote:Make sure it gets repassivated, Im tellin' ya, it'll make a big difference.
I asked a shop about that and he said that passivization was not needed because the metals were the same....
thanks for the reply
That's a bad answer, for best corrosion resistance passivation is required. Now that said, I can't say what that means in terms of time, I know your using 316 and this will be much better then what you're replacing
