Yes it does matter - the thinner wire, .024" can run at low amps very stable and is great for car body thickness and the 1/8" thickness you are planning to weld.
Each wire has a range that it runs well at, when outside that range (low or high) the arc is unstable and doesn't "run right"
Here is an example chart:
.024" would be even farther left
- image.png (190.38 KiB) Viewed 475 times
