Glowzinski
    Thu Dec 31, 2015 9:08 pm
    Maryland
Ok, I finished welding my guy together. Now, I am trying to weld details on. Mouth, two eyes and I have hair. Any advice, on welding 1/8 aluminum, on top of 1/8 aluminum?
I started having problems again today. No puddle would form. I actually just got the metal hot. Pushed in on the back and out in the front. haha
I have gotten to the point, where i was just going to use that metal cement stuff, to put those few details on. But, I thought I would check on here first.
I am using a Bobcat 250 as a generator and an AHP Alpha tig as my tig welder.
Gene.243
    Sat Sep 27, 2014 8:43 pm
    Southwest Oklahoma
Can we assume that you used this system to weld the butt and corner joints in the photo?
Glowzinski
    Maryland
Indeed. But things have been weird. I can not make a puddle. As I think I said, while trying, it almost cut through the aluminum.
Maybe a spot welder would work. Haha.
I know there is a way to do it. It's just that I cannot figure out, how to get the two together. Do I start the puddle on the bottom metal, part going on or both? I will search and search.
Gene.243
    Southwest Oklahoma
If you can't start a puddle the troubleshooting tree can go two directions. Equipment or operator. On the equipment side Is your welder operating on 110V or 220V. 110V may not have enough power. I am not familiar with your machine but believe it operates on either.
