Coldman
    Mon Dec 15, 2014 2:16 am
    Oz
I'm gonna be working up a PQR/WPS for staino pipe soon. Masking tape on the ends for purging takes time. I found that 2-1/2" OD copper tube (18#) slides over 2" pipe neat so I decided to make up some purge caps. (2" s/s sched 160 pipe will be my test coupons). Sliced some rings and flattened out some copper tube to make the caps. Decided to fuse them together with tig. Tried straight arc, bit like pelican poop. Tried pulse, bingo. Squeezed in the vice to remove gaps.
Settings:
DCEN
sharp 3/32" lanth, No.6 cup
10l/min argon
145amps on the pedal
2.5 pps
50% on time
50% background current
I mashed the pedal when cold to puddle then dropped back to a consistent 106 amps for the run.
Good deal, way to get it done!
jroark
    Thu Jul 16, 2015 2:39 pm
    Ramseur, NC
Very good! Thanks for sharing. I’ve never welded copper. Nice results.
rahtreelimbs
    Mon Jun 14, 2010 10:39 pm
I tried my hand at welding copper a few years ago. About the same as carbon steel. I used copper romex wire as filler rod.
