John Chamorro
- John Chamorro
Location:San Antonio Valley Peoples Republic of Californy
I have a very tight spot to weld a filler neck on an aluminum tank under the 90* elbow. There's about 3/8" between the pipe and the tank and a cup just won't fit in there. I'm thinking about trying 1/2-3/4" stick out and flooding the area with argon from another bottle. I already tried to carry the heat in there but just can't get enough heat to melt the filler and the tank without melting the filler neck. The tank is 1/8" and the filler probably .090 thick ,,, maybe less. Any ideas? Suggestions? The tank is new material and the filler neck is used/old but cleans up as new.
I don't know it all but I'm working on it.
Tried with a bent tungsten tip to get closer?
John Chamorro
- John Chamorro
I'm cheating. I decided to cut the short necked filler off and replace it with another that's already welded to a 4" square and just weld the assy. down . It should be much simpler and cleaner.
- 5th Street Fab
I've had that problem but I was lucky enough to get by with a #5 a long stick out and high cfh.John Chamorro wrote:I'm cheating. I decided to cut the short necked filler off and replace it with another that's already welded to a 4" square and just weld the assy. down . It should be much simpler and cleaner.
Sent from my XT1635-01 using Tapatalk
If such hard to access jobs come by more often then perhaps something like these might be an option to invest in (watercooled probably to get the max amps):
http://www.ckworldwide.com/micro-torch.html
http://www.ckworldwide.com/180-amps-ck180.html
Bye, Arno.
Bye, Arno.
