Greybeard
    Tue Aug 05, 2014 5:09 pm
    CT
When attempting lay wire technique the filler just melts and runs away from the puddle.
What am I doing wrong please?
    Sun Oct 27, 2013 10:57 pm
I think you'll need to be more specific to get good answers.
Amps, thickness of material, torch angle, filler size, type of weld, etc.
I've never done lay wire for aluminum, only steel.
nelson
    Sun Jul 17, 2016 1:21 pm
    near philly
I started by laying the wire and kicking pedal...got the same result.
Now I start the puddle then scoot the wire in and lay it. I move the torch and work the amps with the base my main concern. The wire melts and joins the puddle.
If I go too fast what you describe happens.
The wire is easy to melt and close to the arc. That makes the start a bear. Fun technique with practice.
I've done the lay wire, but only when walking the cup.
What material are you welding? What is the diameter of the filler?
Greybeard
    CT
.125" 6061 cleaned & brushed, 3/32" filler, T joint, amps were up there but forget precise setting, working the pedal anyway.
20 CFH.
Miller 180, stubby gas lens, 3/32 2% lanthanated.
dave powelson
    Mon Nov 24, 2014 3:09 am
    yuba city, CA
lay wire pic
lay wire pic
P6270003 12w lay rod arrow .jpg (18.29 KiB) Viewed 3403 times
In the above pic, the filler end is melted and drawn by capillary action into the puddle--puddle's literally
sucking off the rod end.
Above is welding reinforcement corner gusset (1/8") to top of old 1/16" diamond plate toolbox.
Once the puddle is established and filler added to advance it slightly, end of filler is placed at the fluid
toe puddle-either right or left side, to create a melt path to the puddle.
With heat management, torch motion & angle, the puddle is advanced while continuously being fed by the filler end.
Filler is advanced some, into the puddle zone. As others mention--lay rod or lay wire requires 'a little' bench time :)
dynasty 350 setup notes
5356 filler
Advanced squarewave form
GEN start
1/16 Lan for crack welds, switched to 3/32 for plate welds
#7 gas lens 100%AR
70% balance for cracks went down to 65% for plates
2 EN : 1 EP
150 AC Hz
100 amps max for cracks, 140 amps max setting for plates
'Stang
    Sun Aug 03, 2014 11:12 pm
    Rogersville, MO
Greybeard wrote:.125" 6061 cleaned & brushed, 3/32" filler, T joint, amps were up there but forget precise setting, working the pedal anyway.
20 CFH.
Torch angle is critical on aluminum. I have never tried to do laywire on aluminum. The laywire method uses a torch angle that probably wouldn't work with aluminum. You'll melt the filler before it hits the puddle. Hope this helps! Maybe someone with more experience chimes in!
Greybeard
    CT
5356 filler
GEN start
#7 gas lens 100%AR
2 EN : 1 EP
150 AC Hz
And your arc is right at the front of the puddle?
By this time the rod would be half way up my glove!
I know... "practice " :D
dave powelson
    yuba city, CA
....No, if arc was at front--filler end would melt away.
For bridging this gap, I suspect torch angle was pointed back at puddle.
I use a CK flex lok torch, adjusting as needed, without wondering what the torch attitude
and angle is, since I'm not instructing.
There's no back and forth, dabbing--the puddle's being worked and advanced, while
the rod keeps being fed into the puddle. It's a fast way to run a joint, faster than dabbing.
I know... "practice " :D[/quote]
Ant428
    Wed Nov 15, 2017 10:22 am
I only use laywire when walking the cup or pulsing. Have you tried pulse? Maybe then the puddle won't consume the rod like you described?
