Artie F. Emm
- Artie F. Emm
Any strength added, or value of any type, if you were to drill 1/2" holes in the outer sleeve, and plug weld to the inner sleeve?
Dave
aka "RTFM"
aka "RTFM"
Others who know what they're talking about can answer that better but I wouldn't try that, feels like adding unevenly distributed welds can add stress risers and uneven tension. I want to make the joint as uniform all around as I can.
Turned out well! I still can't quite wrap my head around how much welds make metal move around. I know it does but I find it hard to "feel" like it's real. My friend machined it to such a press fit that he needed to use his mill table to assemble it. He adjusted it to a 0.002"ish runout and handed it over to me. I hit it with quick hot tacks every 120 degrees. Then did an autogenous root followed by a cover pass. It was up to almost 0.03" runout! I feared I'd need to cut it back apart, readjust and reweld but I went over with the pulser over the entire joint again and an extra pass where it was "long". Then hit it with compressed air as I checked it. Now it's back down to 0.0025" runout. I don't have a pic of the final weld but I'm very happy with it. It's barely above surface and the ripples are very tight and shallow (the final pass before the air gun was at a high pulse rate). I definitely penetrated to the sleeve so I think it's as good as I can make it.
- 25358291_10211224158700898_992663562829098431_o.jpg (65.29 KiB) Viewed 1325 times
- 25352190_10211224157860877_3914895812190729801_o.jpg (72.41 KiB) Viewed 1325 times
- 25182374_10211224158260887_7227622408892209580_o.jpg (37.6 KiB) Viewed 1325 times
- 25438961_10211256380186415_5649011758408947722_o.jpg (65.92 KiB) Viewed 1325 times
- 25394916_10211256380226416_348625137451650648_o.jpg (70.33 KiB) Viewed 1325 times
- IMG_4292.JPG (36.78 KiB) Viewed 1325 times
- IMG_4294.JPG (37.7 KiB) Viewed 1325 times
