Here's mine:
Just finished a home built larger arm for a LED work light from Lowes, can be positioned in any hole on the table. The Cert-Flat table has an extra 1/4" top for a total of 9/16" thickness. In the center of the table is a Lincoln Miniflex fume extractor, and notice the 5/16" aluminum ramp (on the floor) so there's no tripping over the 220 volt cord.
- tungstendipper
- Let's see YOUR table!
- weld (6 of 1).jpg (260.94 KiB) Viewed 1798 times
Everlast 210 EXT
CJ737
Everlast 210 EXT
CJ737
- tungstendipper
Thanks! It holds up to 4ft. scraps 90 degrees from the short pieces shown up front. The scrap idea evolved from a gluing table I built 35 years ago. Built out of wood, it had a 3/4" dip in the middle of the table, and would catch on fire when I would plasma cut on it. I used it for over 35 years! This welding table is a dream!Bradk wrote:Tungstendipper,
Very well thought out table. I like the little storage shelf on the right underside for rat holing scrap, sweet! Looks very comfortable as well.
Brad K
See pic
CJ, Your table is beautiful!!!! Looks as accurate as a granite block inspection table!
- weld (7 of 1).jpg (77.26 KiB) Viewed 1741 times
Everlast 210 EXT
CJ737
Everlast 210 EXT
CJ737
Tungstendipper,
I did not notice your lathe and grinder in the background behind your Everlast welder? Looks like Metal Central. A small industrial corner of your garage. Nice organization of metal specific tools.
Bradk
Bradk
- tungstendipper
Thanks! It's no big deal, many have much more. I'm truly grateful just to have a warm shop to work in. It's mainly a wood shop and my Dad was a machinist and I inherited the lathe and a lot of tooling.Bradk wrote:Tungstendipper,
Bradk
Everlast 210 EXT
CJ737
Everlast 210 EXT
CJ737
