Mcloer
    Tue Jun 20, 2017 1:50 pm
    Madison, MS
When setting up to tig in a tight/small space recently I was having difficulty seeing where to position my torch and filler rod with the helmet down. I searched and found a small very high lumen led light. Placed a velcro strip under and around it to secure it to my helmet and voila, problem solved! Another $20 well spent.
RETIREMENT DOES NOT SUCK!!!!!
homeboy
    Mon Dec 19, 2016 11:52 pm
    Southern Ontario Canada
Good idea. Never tried the headlite trick. Because I just use mild steel I use a little swiveling led with a magnetic base that I can usually make work. :D
