Nothing fancy, just recycling some old 5"x5"x 4.8mm square tube to make into a rack to hold my steel/aluminum.
Welds are nothing to look at; edges were rough-cut with plasma using no guide, I was purposely long-arc'ing it, stubbing into the weld puddle to purposely stick the rod (as I tried different Arc Force settings), trying different hot-start settings. Just getting an over-all feel for it. The verdict: This. Little. LUNCHBOX. kicks. a$$. Even without setting it to cellulosic mode, it lit up Lincoln Pipeliner 6P+'s (E6010s) without even the slightest hesitation (with correct amperage, and appropriate H.S & A.F.). I think if I do set it to cellulosic mode, 6010s will probably just obliterate into dust! But really, it has a real nice arc, very forgiving, and easy-start's all the rods I tried, from Lincoln Excalibur 7018MR H4R, to Pipeliner 5P+/6P+, to cheapie "Best Welds" and Blue Demon rods. It gobbled them up and spit them out.
